How to adjust acceleration
- yi2580
- Thank you received: 3
14 Jul 2021 08:21 #214689
by yi2580
How to adjust acceleration was created by yi2580
Excuse me, how can I adjust the axis acceleration?
Thank you.
Thank you.
- Thank you received: 2176
14 Jul 2021 09:57 #214702
Replied by Aciera on topic How to adjust acceleration
in your INI file [AXIS_n]-section you can define MAX_ACCELERATION
The following user(s) said Thank You: yi2580
- yi2580
15 Jul 2021 01:44 #214800
by yi2580
Replied by yi2580 on topic How to adjust acceleration
I may not know much about this, but isn't this the way to adjust the maximum acceleration? If this is adjusted, how should the maximum limit acceleration be set?
Thank you for your reply!
- yi2580
15 Jul 2021 01:46 #214801
by yi2580
I may not be very good at using this forum. I don't know if you can receive my reply?
15 Jul 2021 06:42 #214812
I think I don't understand what you are trying to do. What would be the difference between 'maximum acceleration' and 'maximum limit acceleration'?adjust the maximum acceleration? If this is adjusted, how should the maximum limit acceleration be set?
- yi2580
15 Jul 2021 07:07 #214813
by yi2580
Thank you very much for your reply. I want to set an acceleration and the maximum acceleration. I don't know how to modify these two data. What your said should be acceleration. I don't know if I have expressed my meaning clearly. My English is not very good.
Thank you again for your reply
- yi2580
15 Jul 2021 07:10 #214815
by yi2580
It is equivalent to setting an acceleration and a maximum limit acceleration. The acceleration I set cannot exceed this maximum limit acceleration
15 Jul 2021 09:11 #214822
The idea is that the user sets only the acceleration limits his machine setup can handle.
You can set limit accelerations for the machine as whole, for a joint (used for movements in joint mode) and for an axis (used after homing).
The actual acceleration is then determined by the motion planner that tries to maintain constant velocity and one of it's tasks is to make sure acceleration does not exeed any limits set by the user.
- yi2580
15 Jul 2021 09:14 #214823
by yi2580
Yes, it is necessary to add limited acceleration. How can I set it
Thank you very much
Thank you very much
15 Jul 2021 09:42 #214827
in your INI file
[TRAJ]-section you can define MAX_LINEAR_ACCELERATION
[JOINT_n]-section you can define MAX_ACCELERATION
linuxcnc.org/docs/html/config/ini-config.html
Time to create page: 0.116 seconds
