Homing failure only on Y axis
- Thank you received: 4149
14 Sep 2021 00:41 #220538
Replied by rodw on topic Homing failure only on Y axis
What happened made sense to me. If a home switch is already enabled on power up, Linuxcnc will think its on the wrong side of the home switch location and move off it before continuing with the home sequence. But in your case, the condition never cleared.
Always trust Linuxcnc's homing if it does not work as expected, always check hardware first!
The following user(s) said Thank You: philcobt
- philcobt
14 Sep 2021 11:59 #220579
by philcobt
Replied by philcobt on topic Homing failure only on Y axis
Thanks Rod
If I had seen your comment first it would have been spot on
Cheers
Barry
Cheers
Barry
Time to create page: 0.712 seconds
