7i76e use outputs to toggle motor enable
4 years 9 months ago #231888 by pCNC
As easy as promised :D
I've set up output 008 on I/O Connector 1 as "Machine Is Enabled" in pncConf, and connected pin 4 of TB3 (DIR4-) to all the motor enables, so they are toggled all together.
The alarm signals are now linked to joint.N.amp-fault-in, using the attached custom_postgui.hal.
Now when one of the motors goes into error, Linuxcnc shows an joint amplifier error and takes away the enable for all joints. When I toggle the enable, everything can be jogged/homed again, without power cycling the drives.
The error is reset almost immediately (at least way before I can go look for a red light) instead of when I toggle the enable again, so either something is slow (my very old laptop for instance) or the driver responds a little differently than I was expecting.
It was confusing for a moment, but it is workable and I can continue working from here :)
Thanks for the tips!
4 years 9 months ago #231889 by pCNC
Oops, forgot to insert the attachment...
File Name: custom_pos...1-15.hal
File Size:560 B
4 years 9 months ago - 4 years 9 months ago #232633 by strahlensauger
I own JMC ihvs57 servos, in the documentation I find:
"Enabling signal: This input signal is used to enable or prohibit; In addition, it can be used to clear the drive alarm. When ENA + is connected to +5 V, ENA-is connected to low power, the drive will cut off the current of each phase of the motor so that the motor is in a free state, where the pulse is not responded and the alarm can be cleared; When this function is not required, the energy signal end is suspended."
So the ENA+ only needs a short pulse to clear the drive, I can't connect the output signal from the 7i76e directly to the ENA+, because it is always on, apart from that the servo accepts only 5 Volts.
In the discussion above the signal is always high on the enable-amp  output as far as I understood, any ideas how to connect the ENA+ input in my case?
I could just put a physical push-button inbetween a 5 Volt line, but I would prefer clearing the servos directly from Linuxcnc, something like a button in pyvcp. (Does a push button exist)?
Last edit: 4 years 9 months ago by strahlensauger.
4 years 9 months ago #232642 by chris@cnc
I recommend to use the ENA signal as high bit to enable the drive after E-stop or alarm. if you have any alarm on this easy drive it’s have a reason and could not done by reset. usually restarts machine necessary.
The following user(s) said Thank You: strahlensauger
4 years 9 months ago #232674 by rodw
iocontrol.0.user-request-enable sends a pulse when the estop is cleared. You would need an optocoupler or fast signalling relay to switch 5v to the drive. Maybe it could be made to work.
4 years 9 months ago #232717 by strahlensauger
That sounds promising, I'll check that out.
Thank you.
Time to create page: 0.226 seconds
