hm2: Firmware contains unknown function (gtag-45)
23 Jun 2022 00:41 #245632 by PCW
What is the actual error that you get?
23 Jun 2022 01:17 #245635 by TriCnC2022
Replied by TriCnC2022 on topic hm2: Firmware contains unknown function (gtag-45)
Using POSIX non-realtime
. /my LinuxCNC machine.hal: 10: parameter or pin 'hm2 7196:0.watchdog. timeout ns'
That error. I will take screen shot when I get home tonight or try to figure how to post my error like I see how others do it.
off topic, I’m currently testing my old 6040 Chinese machine on another Linux setup    using parallel port and it works like a charm. I Immediately love the Linux system. So on my custom built mill with ATC I need a little bit more I/o  so therefore I’m trying to test out the Mesa 7i96s. Here a link to my mill currently running Mach3.
23 Jun 2022 01:24 #245636 by PCW
If this is a 7I96S that is an error on the hal file since that's the wrong card name
(should be 7i96s)
23 Jun 2022 01:32 #245637 by TriCnC2022
That makes logic sense. So how would one fix this? Thanks again
23 Jun 2022 01:54 #245638 by PCW
Globally replace 7i96 with 7i96s with a editor is one way, but how was the hal file generated in the first place?
if it was made for a 7I96s it should not use 7i96 as a card name
23 Jun 2022 02:15 #245641 by TriCnC2022
Under pncconf wizard. I don’t have the option to select 7i96s. But the 7i96 and other board are an option. Did I miss something?
23 Jun 2022 02:20 - 23 Jun 2022 02:22 #245643 by PCW
You could use JTs MesaCT which has direct 7i96s support
or edit the pncconf generated hal file or ini file
(With pncconf created hal/ini files the card name can
either be spread throughout the hal file or just appear once
in the ini file depending on a setup option)
Last edit: 23 Jun 2022 02:22 by PCW.
23 Jun 2022 02:38 #245647 by TriCnC2022
Ok. I’ll look into it this weekend.  Thanks for all your input. I’ll keep you posted on how it went.  Take cares.
23 Jun 2022 23:02 #245739 by andypugh
This looks wrong. It seems that you are running the wrong Linux kernel.
24 Jun 2022 02:06 #245750 by TriCnC2022
I’m using rt kernel. Is there a certain one that need to be use to make it work properly?  I am fairly new to Linux and trying to understand how it works.
Time to create page: 0.120 seconds
