Remora + Octopus Pro Dirhold and Dirsetup Issue
- 4170-thomasnobi
- Topic Author
3 years 11 months ago #257209
by 4170-thomasnobi
Remora + Octopus Pro Dirhold and Dirsetup Issue was created by 4170-thomasnobi
Hello all,
I am running LinuxCnc with an Octopus Pro board and Remora firmware. All works fine except that the servos motors make cracking noises when reversing the load. With the oscilloscope I see that when the DIR Pin changes also the first Puls starts (~120ns). I assume that the problem comes from there. But I can not find a setting where I can set the values for Dirhold and Dirsetup.
I have tried:
setp remora.joint.0.dirhold 10000
setp remora.joint.0.dirsetup 10000
Remark from the Servo Manuel:
(1) t1: ENA must be ahead of DIR by at least 5μ s. Usually, ENA+ and ENA- are NC
(not connected).
(2) t2: DIR must be ahead of PUL active edge by 6μ s to ensure correct direction;
(3) t3: Pulse width not less than 2.5μ s;
(4) t4: Low level width not less than 2.5μ s.
My hardware:
Rasperry Pi4 4Gb with the RT image.
Octopus Pro Board via SPI
JMC IHS57 Servos
Software:
LinuxCNC 2.8.3
Remora 1.1.0
I hope someone can help me.
Thanks and greetings
Thomas
I have tried:
(not connected).
My hardware:
JMC IHS57 Servos
Software:
LinuxCNC 2.8.3
Remora 1.1.0
Thomas
3 years 11 months ago #257420
by cakeslob
Replied by cakeslob on topic Remora + Octopus Pro Dirhold and Dirsetup Issue
Yeah, good question. Bring this question over to the main thread.
forum.linuxcnc.org/18-computer/42276-rem...er-via-spi?start=610
I recently migrated a config from hm2 to remora the other day, and set this in ini without out checking if it was actually connected to anything.
Time to create page: 0.079 seconds
