- Configuring LinuxCNC
- Basic Configuration
- After successfully homing all - Y axis lurches in negative direction
- Doug @ Design8Studio.com
- Thank you received: 46
10 Jan 2023 16:04 #261462
by Doug @ Design8Studio.com
After successfully homing all - Y axis lurches in negative direction was created by Doug @ Design8Studio.com
My issue sounds identical to this topic's OP:
"After Home - Y axis takes off in negative =SOLVED"
forum.linuxcnc.org/38-general-linuxcnc-q...gative-solved#261458
The answers there were:
Thanks in advance for any nudge in the right direction!
- Make Y axis homing velocity negative — I think mine already is?
- Flip stepper motor wiring so the stepper spins the other way — I can do this, but since the homing is already moving in the right direction, doesn't that mean the stepper motor wiring is already correct?
10 Jan 2023 16:26 #261466
Replied by Doug @ Design8Studio.com on topic After successfully homing all - Y axis lurches in negative direction
As requested here is video of the successful homing followed by a lurch in Y-min direction:
- Thank you received: 7478
10 Jan 2023 16:52 #261471
Replied by tommylight on topic After successfully homing all - Y axis lurches in negative direction
Home = -30
For both Y
For both Y
The following user(s) said Thank You: Doug @ Design8Studio.com
10 Jan 2023 17:14 #261473
Wow, that's an easy fix. And now that I realize it was my own doing because the tutorial I was following calls for moving to another corner away from Y-min to "park" out of the way for the insertion of metal for a job, and I was missing that it was that, not homing! I feel sheepish! Thank you!
10 Jan 2023 17:43 #261475
Just reporting back that the fix was indeed to change the final home location from 30 to -30!
Thank you so much!
Thank you so much!
10 Jan 2023 21:47 #261497
Update: Just now realizing this issue both was and is directly related to the later discovered situation of what seems like "backwardness" of all axes, which I'm inquiring about here:
forum.linuxcnc.org/49-basic-configuratio...l-axes-jog-backwards
In the matter in this thread, I had asked for a move 30" in the Y+ direction to park the cutter. It was moving in what to me seems like the Y- direction, which during homing is treated as the Y- direction.
Basically, I had to change to asking for a negative direction to achieve what seems to be a positive direction.
Time to create page: 0.146 seconds
