- Thank you received: 6
Delta MS300 VFD, RS485, RPI4, QTdragon, getting it to work
- Calysto
2 years 9 months ago - 2 years 9 months ago #290336
by Calysto
Replied by Calysto on topic Delta MS300 VFD, RS485, RPI4, QTdragon, getting it to work
Yesterday I've made a teamviewer connection between my home-pc and my cnc-machine (that's in a cold space), that gave me an nice environment to test thing. And... mb2hal is working! I've attached my mb2hal config. I'm not happy with the naming yet. I expected all names like mb2hal.spindle.[pin-name]. But only the first transaction is named that way.
But...... I have EMI problems I think, When I stop my spindle, usb-devices often stops working.
My PI is connected to my Delta MS300 via usb, using the inbuild rs485 converter of the VFD. What shell I do? Use mesa_modbus and eliminated the use of a usb-cable? Do I need another firmware to use mesa_modbus on my 7c80? I probably have to put my 7c80/PI4 in a steel box too... I'll ask this kind of things on the printnc-discord...
Last edit: 2 years 9 months ago by Calysto.
The following user(s) said Thank You: PHILCOAST
- Calysto
2 years 9 months ago - 2 years 9 months ago #290409
by Calysto
The firmware's for the 7c80 doesn't seam to have pktUart enabled. I've asked Mesa for help. Compiling the mesa_modbus driver was the easy part
- Calysto
2 years 9 months ago #291127
by Calysto
It looks like I've solved my electrical problems, changed some cables and used some ferrite cores.
@PCW: Can you help me getting PktUART working on my 7c80? There is no firmware on the mesa-website that supports PktUART...
- PHILCOAST
- Thank you received: 3
2 years 7 months ago #296499
by PHILCOAST
Replied by PHILCOAST on topic Delta MS300 VFD, RS485, RPI4, QTdragon, getting it to work
Hi Calysto,I use the same components as you. RPI4 on 7c80 and MS300.
I am currently using the PWM terminal to control the spindle. Can you share the whole configs folder with me?
This will help me a lot to understand by comparing the differences.
- Calysto
2 years 7 months ago #296537
by Calysto
Here it is. I use 2.9.2. The joypad does not work correctly yet. Where you are looking for should be in the "4_QT_spindle", "9_QT_postgui" and "mb2hal_MS300" files.
Happy to hear I'm not the only one with this setup
I've connected my VFD with an usb cable to my PI. I hope there will be Pktuart firmware for the 7c80, so we can use the RS422 connector.
If you have questions, let me know....
- Thank you received: 5334
2 years 7 months ago #296589
Replied by PCW on topic Delta MS300 VFD, RS485, RPI4, QTdragon, getting it to work
Time to create page: 0.340 seconds
