Delta MS300 VFD, RS485, RPI4, QTdragon, getting it to work
2 years 9 months ago - 2 years 9 months ago #289984 by Calysto
I'm just talking to myself, that helps too :-)
So, it depends on your VFD what kind of read/write types are supported. In my manual there is no paragraph about that, but there is something that looks like it. They are talking about the following functions:
fnct_03_read_holding_registers (03 = 0x03)
fnct_06_write_single_register (06 = 0x06)
fnct_16_write_multiple_registers (16 = 0x10)
So, that's where I have to deal with.
I'm afraid that I need conversions in my HAL-file then....
Last edit: 2 years 9 months ago by Calysto.
2 years 9 months ago #290002 by tommylight
I did read it :)
I try to read everything, not always possible.
The following user(s) said Thank You: Calysto
2 years 9 months ago #290101 by Calysto
:-) Maybe I want to much....  I found this on the printnc discord. I guess I have to do it like this.... Although my brain says: that can't be in 2024!!! :-) Mux-ing and scaling should be done bij mb2hal, but that's my opinion.
#******************* #  SPINDLE #******************* # Start/Stop -- Command Selector Mux loadrt mux4 names=mux4.runmode addf mux4.runmode servo-thread # bit 0-1 : Stop=0b01, Run=0b10 # bit 2-3 : reserved # bit 4-5 : Fwd=0b01, Rev=0b10 # Fwd command: 0x0012 -> 18 # Rev command: 0x0022 -> 34 # Stop command: 0x0001 -> 1 setp mux4.runmode.in0 1        # Stop setp mux4.runmode.in1 34    # Reverse setp mux4.runmode.in2 1        # Stop setp mux4.runmode.in3 18    # Forward net spindle-on        spindle.0.on => mux4.runmode.sel0 net spindle-fwd        spindle.0.forward => mux4.runmode.sel1 net spindle-runmode    mux4.runmode.out => mb2hal.spindle_runmode.command # Speed loadrt mult2 names=mult2.speedmult,mult2.fbspeedmult addf mult2.speedmult servo-thread addf mult2.fbspeedmult servo-thread loadrt near addf near.0 servo-thread setp mult2.speedmult.in0 100 net spindle-setpoint    spindle.0.speed-out-rps-abs => mult2.speedmult.in1 net spindle-freq    mb2hal.spindle_speed.freq_hz <= mult2.speedmult.out setp mult2.fbspeedmult.in0 0.6 net spindle-freq-fb    mult2.fbspeedmult.in1 <= mb2hal.spindle_speed_feedback.fb_freq_hz.float net spindle-speed-fb    <= mult2.fbspeedmult.out setp near.0.scale 1.01 net spindle-setpoint-rpm    spindle.0.speed-out-abs    => near.0.in1 net spindle-speed-fb        => near.0.in2 net spindle-at-speed    spindle.0.at-speed <= near.0.out
2 years 9 months ago #290106 by pawel77
Hi Calysto,
before communicating with VFD via Modbus I would buy a simple modbus input/output relay and start practicing modbus and MB2hal.
Do you know if is it possible to position spindle with MS300?
2 years 9 months ago - 2 years 9 months ago #290193 by Calysto
A few days ago I didn't know anything about modbus... now I know much more... The most important thing is that I've learn that not every device supports reading at bit-level, that's why I see people using mux4/enum/weighted_sum.
The Delta MS300 manual says that adres 2000H, bit 0 and1 made high, should make it able to Jog... but I've never used it. I also don't know if that is spindle depended.There is a lot to read about jogging in the manual, but I'll probably never use it
2 years 9 months ago #290202 by Calysto
To make things even more interesting (or difficult :-)) I will also try Mesa_modbus. I'm not sure if it will work with my 7c80, but there is a serial port on it, it should be on with my firmware. Wil test everything later... my machine is not nearby....
Mesa_modbus config-file I've made so far:
static const hm2_modbus_chan_descriptor_t channels[] = { /*  {TYPE,     FUNC, ADDR,   COUNT, pin_name} */     {HAL_BIT,   3,   0x2000, 6,   "runbits"},     {HAL_FLOAT, 3,   0x2001, 1,   "freq"},     {HAL_FLOAT, 6,   0x2106, 1,   "volt"},     {HAL_FLOAT, 6,   0x210A, 1,   "amp"},     {HAL_S32,   6,   0x210C, 1,   "rpm-out"}, };
The following user(s) said Thank You: PHILCOAST
Time to create page: 0.144 seconds
