Custom inputs/outputs
- Walkahz
- Thank you received: 7
08 May 2024 10:13 #300105
by Walkahz
Custom inputs/outputs was created by Walkahz
Hi everyone.
I am retrofitting and old deckel fp4 using a 7i96 and 7i84d combo.
I have lots of inputs and outputs that are"custom" for lack of a better word and not available to select in the pncconf wizard, the closest to a generic output would be digital in/out 1 2 3 4.
What is the best way to include these in hal? Is there a way they can be added in pnccconf or do they need to be written manually into HAL?
I am very green to LCNC so sorry if it's a basic question.
- Thank you received: 7478
08 May 2024 10:37 #300108
Replied by tommylight on topic Custom inputs/outputs
Probably manually in hal, have a look here what i usually do, write those down in a puece of paper and add them to hal manually
forum.linuxcnc.org/show-your-stuff/32784...ofit?start=40#254368
The following user(s) said Thank You: Walkahz
Time to create page: 0.119 seconds
