Troubleshooting Analog AC Servo - Full Speed at "Analog Scale Max = 0"
  • Saggy_headliner
  • Saggy_headliner's Avatar Topic Author
  • New Member
  • New Member
08 Sep 2024 14:04 #309656 by Saggy_headliner
Bench testing my configuration 7i96s + 7i77 with 1 Yasakawa AC Servo drive (SGDA-04AS) w/servo. Goal here is to get a baseline for PID settings.
Drive enable is an "active low" type and upon initial wiring I experienced a "chatter" with the relay. I fixed this by integrating a filter onto power leads for my bench setup. I'm still not 100% convinced I've eliminated all noise from the system, however, the issue below does not seem noise is root cause.
Issue: When setting parameter "hm2_7i96s.0.7i77.0.1.analogena" to enable, the servo immediately vibrates and the axis will rapidly move back and forth (the encoder does record this movement) in small increments. In the "calibration" settings, I've tried messing with the PID values to attempt to dampen this out and have observed no change. However, when I set the "ANALOG_SCALE_MAX" from it's default value to 0 and enable the drive, the servo will immediately spin at what it seems to be full speed until I disable the drive. I've changed servo drives and replicated this behavior so it seems it's something to do with my configuration.
Any idea what is going on here?
  • Moderator
  • Moderator
09 Sep 2024 13:34 #309746 by tommylight
First the drive must be tuned to the attached motor, with it's own software, follow the procedure as described in the drive manual.
No LinuxCNC at all, until the drive is set up properly, as it is impossible to tune or use.
And a friendly warning, do not change stuff at random and hope it works, usually end up in tears or frustration.
forum.linuxcnc.org/38-general-linuxcnc-q...oder?start=10#309742
forum.linuxcnc.org/10-advanced-configura...to-example-mesa-7i77
Time to create page: 0.257 seconds
