7i96s not recognized
31 Dec 2024 20:37 - 31 Dec 2024 21:30 #317733 by slowpoke
7i96s not recognized was created by slowpoke
New installation of Linux2.9.3 on a Lenovo Yoga
I followed the tommylight Ethernet setup for 7i9x and can't seem to get Linux to recognize the 7i96s
Power LED and the green user LED's change status, I'm getting a swirly network icon up in the top right that I assume is indicating it's trying to connect.
Settings and error are as shown in attached.
I also tried moving the jumpers from the default 192.168.1.121 to EEPROM and same result except can't connect to 10.10.10.11
Suggestions?
Last edit: 31 Dec 2024 21:30 by slowpoke.
31 Dec 2024 21:28 #317736 by PCW
Replied by PCW on topic 7i96s not recognized
Set the IP address in the hal file to 10.10.10.10
(and make sure the 7I96S is set for 10.10.10.10)
  • Moderator
  • Moderator
31 Dec 2024 21:36 #317737 by tommylight
Replied by tommylight on topic 7i96s not recognized
- choose "manual" on the "method" drop down menu
Apparently you missed a step, you still have it set to automatic.
31 Dec 2024 22:23 #317744 by slowpoke
Replied by slowpoke on topic 7i96s not recognized
I tried that, same result.
I'm pretty clueless when it comes to LAN ports etc. I verified my CAT cable is okay (tried it on a working LinuxCNC machine)
The new Linux machine is using a docking station for the ETHERNET port, I would like to rule that out that as a problem. Are there some commands I can execute on the command line to verify that the ETHERNET port is actually visible to Linux?
I also have a Windows based laptop with an Ethernet port that I could connect with a CAT cable and see if the two can see each other?
I also have another working LinuxCNC machine with an Ethernet port that I could connect with a CAT cable and see if the two can see each other?
I'm looking for a way to confirm that ETHERNET port on the docking station is actually working.
Any help would be appreciated.
31 Dec 2024 22:34 - 31 Dec 2024 22:43 #317745 by PCW
A couple notes:
1. The IP address in the hal file must match the Mesa card IP address
2. If you change the Mesa card's IP address jumper, you must cycle the card
power for the change to take effect
3. The host IP address cannot be the same as the Mesa cards IP address
but should be in the same 254 host subnet (only last digit different)
Also last digit cannot be 0 or 255.
4. You can determine you host IP setup with the command:
ip a
5. When LinucCNC is not running, you should be able to ping the card
for example:
ping 10.10.10.10
Beware: if you set the host address to say 10.10.10.10, you will get  responses
to the ping command from the host rather than the Mesa card
Last edit: 31 Dec 2024 22:43 by PCW.
The following user(s) said Thank You: slowpoke
01 Jan 2025 01:01 #317749 by slowpoke
A couple notes:
ip a
for example:
ping 10.10.10.10
Okay some progress,
Both the wired connection and CX7076-R0.hal are set to 10.10.10.10 and ipv4 is manual
I can now ping 10.10.10.10 (that's new)
Linux still does not start, might be #3 above host subnet?
please see ip a result attached.
01 Jan 2025 01:40 #317752 by PCW
Yes, you are pinging yourself (I hear that may make you go blind)
I would set the host address to 10.10.10.100
01 Jan 2025 11:09 #317767 by slowpoke
Getting closer...
To set the host address can I use  "sudo nano /etc/hosts " ?
Assuming yes, presently set as follows:
   127.0.0.1 local host
   127.0.1.1 LinuxCNC-Lathe
Do I edit just the 127.0.0.1 to 10.10.10.100  or should I edit both lines and if both lines, what address should I set the LinuxCNC-Lathe to?
Much appreciated.
  • Platinum Member
  • Platinum Member
01 Jan 2025 12:10 #317768 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic 7i96s not recognized
The hosts file is one method for host name resolution. It's not used for setting the IP address of a host.
If you had a small network of 4 computers that didn't require connection outside of the network and you didn't want to run a DNS server you would create a hosts file with all the mappings and then be able to access each machine by their DNS entry in the hosts file.
01 Jan 2025 13:41 - 01 Jan 2025 13:43 #317776 by slowpoke
This is a dedicated PC for LinuxCNC for my lathe. It has built in WiFi that connects to our home network. The Ethernet port is dedicated to the MESA card. I don't plan to connect with anything else via that Ethernet port, just the Mesa card.
Last edit: 01 Jan 2025 13:43 by slowpoke.
Time to create page: 0.913 seconds
