Coordinate system in GUI does not match machine
14 Jan 2025 20:02 - 14 Jan 2025 20:12 #318978 by DieLimo
Hello everyone,
I probably have a very simple beginner's question that I just can't figure out how to solve.
I have a milling machine with x,y and Z travel and my home coordinate system is at the top right. I assume that you can do it this way or is this fundamentally wrong?
So that my coordinate system looks like this:
But the coordinate system in the GUI shows the opposite.
Video for better explanation: Link to video
I guess that my z-axis is the wrong way? Or the Y-Axis? And I also don't know which parameter I have to change in the ini-file (see attachment)?
Maybe someone can help me out with that.
Best regards
File Name: Fraese2.ini
File Size:2 KB
Last edit: 14 Jan 2025 20:12 by DieLimo.
  • Moderator
  • Moderator
14 Jan 2025 21:39 #318982 by tommylight
Replied by tommylight on topic Coordinate system in GUI does not match machine
None of the above are OK, this is how it is usually done, almost always
forum.linuxcnc.org/38-general-linuxcnc-q...moving-axis-s#309571
You can have it as you want/like, but that will cause issues with every CAM you might use
Here is also the homing stuff
linuxcnc.org/docs/html/config/ini-homing.html
And to reverse motion to any axis, use the StepConf wizard to edit the existing config (or make a new one, you can have many configurations for a single machine), on the pinout page there is a check for reversing the signal to the right of every pin.
15 Jan 2025 18:01 #319041 by DieLimo
Thanks a lot for your two links and the tip with the StepConf. After changing the coordinate system to the near left side, I only had to invert one axis in the StepConf. Now everything works fine :)
  • Moderator
  • Moderator
15 Jan 2025 22:23 #319059 by tommylight
You are welcomed, always.
Time to create page: 0.406 seconds
