Servo Oscillation Issue at ±6.6V 5i25 + 7i77, Analog Control
03 Jun 2025 17:40 #329622 by Traken
What division do you propose, I tried the lowest 625 per mm.
03 Jun 2025 18:15 - 03 Jun 2025 18:17 #329623 by PCW
Does the division change the point at which you get oscillations?
Did you check that the  7i77s 5V is stable?
625 counts per mm is certainly low enough ( < 100 KHz count rate at 8.3 M/min )
Last edit: 03 Jun 2025 18:17 by PCW.
04 Jun 2025 08:29 #329674 by Traken
I haven't checked, but today I will check the only thing I tried to power the 7i77 with a separate power supply but it didn't help.
Time to create page: 0.219 seconds
