neeed help with additional pwm 6i25 and 7i76
24 Mar 2025 22:31 - 24 Mar 2025 22:34 #324841 by mmt
sorry spoke too soon
there are 4 pwm in the terminal command but hal stop on the pwm freq line. i tried it with a hyphen and an underscore
here is my relevant info
Configuration Name: HOSTMOT2
  BoardName : MESA5I25
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 2
  Width of one I/O port: 17
  Clock Low frequency: 33.3333 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 33.333 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 2 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: PWM
  There are 4 of PWM in configuration
  Version: 0
  Registers: 5
  BaseAddress: 4100
  ClockFrequency: 200.000 MHz
  Module: QCount
  There are 2 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: StepGen
  There are 6 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
DB25 pin#             I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
 1                      0   IOPort       StepGen          0        Dir/Table2      (Out)
14                      1   IOPort       StepGen          0        Step/Table1     (Out)
 2                      2   IOPort       StepGen          1        Dir/Table2      (Out)
15                      3   IOPort       StepGen          1        Step/Table1     (Out)
 3                      4   IOPort       StepGen          2        Dir/Table2      (Out)
16                      5   IOPort       StepGen          2        Step/Table1     (Out)
 4                      6   IOPort       PWM              0        Dir             (Out)
17                      7   IOPort       PWM              0        PWM             (Out)
 5                      8   IOPort       PWM              1        Dir             (Out)
 6                      9   IOPort       PWM              1        PWM             (Out)
 7                     10   IOPort       SSerial          0        TXData0         (Out)
 8                     11   IOPort       SSerial          0        RXData0         (In)
 9                     12   IOPort       SSerial          0        TXData1         (Out)
10                     13   IOPort       SSerial          0        RXData1         (In)
11                     14   IOPort       QCount           0        Quad-IDX        (In)
12                     15   IOPort       QCount           0        Quad-B          (In)
13                     16   IOPort       QCount           0        Quad-A          (In)
IO Connections for P2
 1                     17   IOPort       StepGen          3        Dir/Table2      (Out)
14                     18   IOPort       StepGen          3        Step/Table1     (Out)
 2                     19   IOPort       StepGen          4        Dir/Table2      (Out)
15                     20   IOPort       StepGen          4        Step/Table1     (Out)
 3                     21   IOPort       StepGen          5        Dir/Table2      (Out)
16                     22   IOPort       StepGen          5        Step/Table1     (Out)
 4                     23   IOPort       PWM              2        Dir             (Out)
17                     24   IOPort       PWM              2        PWM             (Out)
 5                     25   IOPort       PWM              3        Dir             (Out)
 6                     26   IOPort       PWM              3        PWM             (Out)
 7                     27   IOPort       SSerial          0        TXData2         (Out)
 8                     28   IOPort       SSerial          0        RXData2         (In)
 9                     29   IOPort       SSerial          0        TXData3         (Out)
10                     30   IOPort       SSerial          0        RXData3         (In)
11                     31   IOPort       QCount           1        Quad-IDX        (In)
12                     32   IOPort       QCount           1        Quad-B          (In)
13                     33   IOPort       QCount           1        Quad-A          (In)
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_pci config="num_encoders=1 num_pwmgens=1 num_stepgens=4 sserial_port_0=00xxxxxx"
setp    hm2_5i25.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.a,pid.s
loadrt pwmgen output_type=0
addf hm2_5i25.0.read          servo-thread
addf motion-command-handler   servo-thread
addf motion-controller        servo-thread
addf pid.x.do-pid-calcs       servo-thread
addf pid.y.do-pid-calcs       servo-thread
addf pid.z.do-pid-calcs       servo-thread
addf pid.a.do-pid-calcs       servo-thread
addf pid.s.do-pid-calcs       servo-thread
addf hm2_5i25.0.write         servo-thread
# external output signals
net shutter-output      => hm2_5i25.0.7i76.0.0.output-00
net laser-output        => hm2_5i25.0.7i76.0.0.output-01
# --- LASER POWER ---
setp   hm2_5i25.0.pwmgen.0.pwm_freq 1000
setp   hm2_5i25.0.pwmgen.0.scale 100
net pwm-output hm2_5i25.0.pwmgen.0
net pwm-enable <= motion.motion-enabled  => hm2_5i25.0.pwmgen.0.enable
Last edit: 24 Mar 2025 22:34 by mmt.
25 Mar 2025 00:22 - 25 Mar 2025 00:47 #324847 by PCW
try this:
setp   hm2_5i25.0.pwmgen.pwm_frequency 1000
setp   hm2_5i25.0.pwmgen.00.scale 100
net pwm-enable <= motion.motion-enabled  => hm2_5i25.0.pwmgen.00.enable
net pwm-output hm2_5i25.0.pwmgen.00.value
This assumes pwm-output is a signal that has the current desired PWM value
And delete this line:
Note: if you have a issue with names, you can list all pwm related pin/parameter names with
halcmd show all | grep pwm
(when LinuxCNC is running)
Last edit: 25 Mar 2025 00:47 by PCW.
25 Mar 2025 20:17 - 25 Mar 2025 20:37 #324912 by mmt
now i have no idea what is going on.
with the 5i25_7i76x2_2pd loaded my hal does load the pwm without alarm (i have not checked actual output though) but my A(3) axis does not work. If i revert to 5i25_7i76x2 A axis is good but obviously no pwm
thanks
Last edit: 25 Mar 2025 20:37 by mmt.
25 Mar 2025 20:46 #324918 by mmt
another question
i know the standard io pins can not pwm very fast.
i only need 10K freq can they acheive that?
25 Mar 2025 20:54 #324919 by PCW
thanks
There are only 3 stepgens per 7I76 in that configuration, so that's expected.
You probably need a  configuration with just 1 PWMgen per 7I76.
I can make one when I get a chance.
25 Mar 2025 20:56 #324920 by PCW
another question
Not likely, you need hardware PWM for that.
25 Mar 2025 21:01 #324921 by mmt
i am assuming by your lack of a firmware file one needs to be created. Is there a way I can do this ?
25 Mar 2025 21:03 #324922 by mmt
nevermind i got ahead of myself i now see you said you could create one. That would be much appreciated.
Thank you for all your help
25 Mar 2025 21:51 #324924 by PCW
5i25/6i25 firmware for 7i76X2 last stepgen (04) on each 7I76
replaced with a PWMgen
File Name: 5i25_7i76x...3-25.zip
File Size:113 KB
25 Mar 2025 22:09 #324926 by mmt
Working good now. Thank you so much
Time to create page: 0.213 seconds
