spindle with encoder
13 Apr 2025 23:23 #326237 by vre
spindle with encoder was created by vre
I have a spindle that has motor pulley belt pulley
after has a geartrain with 2 positions-speeds.
I want to mount encoder to second pulley shaft before geartrain.
Iam confused how to set ini file values
max_speed min_speed encoder_scale output_scale etc
14 Apr 2025 21:47 - 14 Apr 2025 21:49 #326320 by vre
Replied by vre on topic spindle with encoder
Motor has inverter that controls rpm of motor via -10V+10V analog signal (mesa 7i33 card).
No can't remove the geartrain. I need encoder for rigid taping.
My problem is how to configure because it is not easy to mount encoder on spindle
shaft must mount it before geartrain of spindle so before 2 selectable speeds reduction is done.
So the problem is that motor has X rpm, encoder has a*X rpm and spindle has b*X rpm or c*X rpm.
What must put in ini file spindle section ?
MAX_OUTPUT = ?
ENCODER_SCALE = ?
OUTPUT_SCALE = ?
OUTPUT_MIN_LIMIT = ?
OUTPUT_MAX_LIMIT = ?
Last edit: 14 Apr 2025 21:49 by vre.
14 Apr 2025 22:01 #326321 by JohnnyCNC
Replied by JohnnyCNC on topic spindle with encoder
If you can squeeze a disc with a notch in it somewhere you can use a slotted optical sensor.  This is my setup and rigid tapping works great.
14 Apr 2025 23:18 #326324 by vre
I will do rigid taping in slow gears speed..
For 2 speeds selection i will use this hal file
#M64 and M65 digital outputs
net sp-shift-high   motion.digital-out-12     mesacard_pin
net sp-shift-low    motion.digital-out-13     mesacard_pin
#M66 Digital Inputs
net  spindle-stoped  motion.digital-in-09    mesacard_pin
net  sp-is-high      motion.digital-in-12    mesacard_pin
net  sp-is-low       motion.digital-in-13    mesacard_pin
and this function
;Erik Salo January 2018
;Okada VM500 Spindle Gearchange program LinuxCNC
;Two speed gearbox. Selects proper range for commanded speed
;Stops spindle prior to gear change
;Special handling for zero, don;t shift down for zero command if in high speed
;Two sensors, one for high and one for low
;Two hydraulic solenoids high and low, turnsoff unselected solenoid
o<setspeed> sub
  o300 IF [#<speed> GT 1250]
  ;Check to see if speed selected is too high
  o010 IF [#<speed> GT 5001]
    (abort, Speed exceeds rated rpm)
  o010 ENDIF
  M66 P12 ;Check if High Gear = True
    o301 if [#5399 GT 0]
      M66 P13 ;Make sure Low Gear = False
        o302 if [#5399 GT 0]
          (abort, spindle still in low gear)
        o302 endif
      S#<speed> ;Set spindle speed with no scaling factor
    o301 endif
  M66 P13 ;Check if Low Gear = True
    o305 if [#5399 GT 0]
      M66 P12 ;Make sure High Gear = False
        o306 if (#5399 GT 0]
          (abort, spindle still in high gear)
        o306 endif
           S0 ; Stop spindle
           M66 P9 L3 Q4 ;Check for spindle stopped - wait up to 4 seconds for digital input 9 to turn on
               o307 if [#5399 LT 0]
                   (abort, spindle not stopped)
               o307 endif
           M65 P13 ; Turn off low gear shift solenoid
           M64 P12 ; Turn on high gear shift solenoid
           M66 P13 L4 Q4 ;Wait for Low Gear = False
               o308 if [#5399 GT 0]
               o308 endif
           M66 P12 L3 Q4 ;Wait for High Gear = True
               o310 if [#5399 LT 0]
                   (abort, spindle not in high gear)
               o310 endif
       o305 endif
o300 ENDIF
;Low Gear Section
o400 IF [#<speed> LT 1250.1] ;Check if requested speed is less than 1250
   o410 IF [4<speed> GT 0.1] Check to see if requested speed is greater than 0.1
       o420 if (#5399 GT 0]
               o421 if [#5399 GT 0]
               o421 endif
   S[#<speed>*2.56] ;Set spindle speed with 4x scaling factor
 o420 endif
   o430 if [#5399 GT 0]
      o431 if (#5399 GT 0]
      o431 endif
    S0 ; Stop spindle
    M66 P9 L3 Q5 ;Check for spindle stopped
      o432 if [#5399 LT 0]
      o432 endif
    M65 P12 ; Turn off high gear shift solenoid
    M64 P13 ; Turn on low gear shift solenoid
    M66 P12 L4 Q4 ;Wait for High Gear = False
      o433 if (#5399 GT 0]
      o433 endif
    M66 P13 L3 Q4 ;Wait for Low Gear = True
      o434 if (#5399 LT 0]
      o434 endif
 o430 endif
o410 endif
 o450 IF [#<speed> EQ 0]
   S0
   ; Set spindle speed to zero
 o450 ENDIF
o400 ENDIF
o<setspeed> endsub [1]
How can set also encoder for rigid tapping ?
15 Apr 2025 01:14 #326329 by JohnnyCNC
My top spindle speed is 5400 RPM and that plate is .032" aluminum. If it does cause vibrations, they are too small for me to notice.
15 Apr 2025 18:31 #326397 by vre
more notches are better but how can i set encoder
if encoder can only positioned before geartrain ?
15 Apr 2025 22:14 #326413 by JohnnyCNC
Hold on a second. I lied. Not intentionally. My spindle motor is a DYN4 servo motor geared 1:1.8 and it has a simulated encoder signal generated by the servo driver. That is the signal I am using for the coordination for rigid tapping. The sensor on the slotted plate it just for measuring RPM.
It's been a few years since I set this up and when you mentioned more slots I thought "I knew that, why didn't I do that?" Then I looked deeper and remembered how it really works.
To actually do this with a slotted plate and sensors you would want more slots and two sensors. Read up on how quadrature encoders work.
As long as you know the ratio between the spindle and encoder you can make almost any arrangement work.
These are my .ini settings.
[SPINDLE_0]
P = 2.0
I = 4.0
D = 0.0
FF0 = 1.08
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
OUTPUT_MIN_LIMIT = -5400.0
OUTPUT_MAX_LIMIT = 5400.0
OUTPUT_SCALE = -10800
ENCODER_SCALE = 4551.111111
#((2048 * 4) / 1.8) = 4551.111111
#The maximum spindle speed (in rpm)
MAX_FORWARD_VELOCITY = 5400
#The minimum spindle speed (in rpm)
MIN_FORWARD_VELOCITY = 50
#This setting will default to MAX_FORWARD_VELOCITY if omitted.
MAX_REVERSE_VELOCITY = 5400
#The minimum spindle speed (in rpm)default to MIN_FORWARD_VELOCITY if omitted.
MIN_REVERSE_VELOCITY = 50
Sorry for the confusion. I hope this helps.
The following user(s) said Thank You: vre
15 Apr 2025 23:42 #326415 by vre
This helps..
What is OUTPUT_SCALE = -10800 ?
This config is for fixed motor:spindle transmition ratio.
I have 2 selectable speeds after encoder-motor
These 2 speeds are selected by hydraulic electrovalve that switches gears
position 1 max rpm is 760rpm and position 2 max rpm 3060
16 Apr 2025 23:21 #326495 by JohnnyCNC
I'm not really sure exactly what is does, but this is where it is used in my hal file.
It looks like it is set to -10800 because 5400 to -5400 is -10800.
# ---Analog output signals/setup---
setp hm2_7i76e.0.7i83.0.1.analogout5-scalemax [SPINDLE_0]OUTPUT_SCALE
setp hm2_7i76e.0.7i83.0.1.analogout5-minlim [SPINDLE_0]OUTPUT_MIN_LIMIT
setp hm2_7i76e.0.7i83.0.1.analogout5-maxlim [SPINDLE_0]OUTPUT_MAX_LIMIT
net spindle-output => hm2_7i76e.0.7i83.0.1.analogout5
18 Apr 2025 10:10 #326585 by andypugh
Replied by andypugh on topic spindle with encoder
Note that unless the index pulse is from the spindle shaft, or the gear ratio is exactly 1:1, you can't peck-tap with the encoder on the motor shaft. This probably isn't a problem in most cases, but is worth being aware of.
Time to create page: 0.438 seconds
