spindle with encoder
- JohnnyCNC
- Thank you received: 115
18 Apr 2025 20:55 #326630
by JohnnyCNC
Replied by JohnnyCNC on topic spindle with encoder
Ah, I took a look at the actual wiring on my machine. I get the A/B signals from the simulated encode in the servo drive and the Z (index) signal from the sensor that is looking at the slot in the disc on my spindle. That is how mine is able to work.
Thanks Andy
Thanks Andy
- vre
- Thank you received: 17
18 Apr 2025 21:02 #326632
by vre
Replied by vre on topic spindle with encoder
What this means?
That for rigid tapping encoder must be on spindle shaft
or must be on 1:1 ratio with spindle shaft?
Other ratio configurations can't work for rigid tapping ?
- JohnnyCNC
18 Apr 2025 21:45 #326637
by JohnnyCNC
The index signal sent to the encoder input to LCNC must be 1:1 with the spindle. My encoder is on my motor. But, I get the index signal from the sensor on my spindle. If the gearing of the motor to the spindle was exactly 1:1 you could attached the encoder to either the motor or spindle. But if the gearing is anything other than 1:1 you must get the index signal from the spindle. My gearing is 1:1.8 and the A/B encoder signals come from the motor side, but my Z (index) signal comes from the spindle side.
The following user(s) said Thank You: tommylight, vre
- vre
21 Apr 2025 11:31 #326801
by vre
So i must attach encoder of encoder disk to spindle shaft because all other places
i can mount the encoder are not 1:1 gear ratio with spindle shaft.
- vre
21 Apr 2025 13:59 #326810
by vre
To mechanically adjust the exact same ratio is very difficult
Also with counter chips division maybe can not be integer multiple
so the only real option is to mount and aluminum disk to spindle shaft
and because my spindle shaft from top has the hydraulic cylinder that locks the tool
the only place can put this is only to the downside of spindle shaft.
How many lines must have the disc for rigid tapping ?
Also must have disc with A B and Z signals or only A is enough ?
21 Apr 2025 18:23 #326827
Replied by andypugh on topic spindle with encoder
You can't do multi-pass threading (lathe, or peck-rigid) if the index isn't 1:1 with the actual spindle.
But, for single-pass rigid tapping it doesn't matter where the index is as long a the encoder scale accounts for the gearing.
21 Apr 2025 18:25 #326828
Also, it is perfectly possible to have the index and A/B phases on different shafts. A prox sensor picking up a keyway / bolt whatever on the spindle can work fine.
The following user(s) said Thank You: vre
- vre
21 Apr 2025 21:02 #326837
by vre
For rigid tapping i need only index signal from spindle shaft
A-B signals can come from elsewhere the encoder is mounted that is not 1:1 ratio correct ?
22 Apr 2025 14:53 #326894
As I said there, you only need the index on the spindle shaft (or 1:1 with the spindle shaft) for multi-pass threading.
forum.linuxcnc.org/49-basic-configuratio...oder?start=20#326827For rigid tapping i need only index signal from spindle shaft
- vre
23 Apr 2025 09:39 #326944
by vre
I have also some backlash to geartrain..
This will be problem for rigid tapping when tap goes backwards ?
If yes then must mount also encoder on spindle shaft..
Time to create page: 0.295 seconds
