spindle with encoder
- langdons
- Thank you received: 93
26 Apr 2025 01:25 - 26 Apr 2025 20:01 #327068
by langdons
Replied by langdons on topic spindle with encoder
Deleted.
Last edit: 26 Apr 2025 20:01 by langdons. Reason: Deleted.
- langdons
26 Apr 2025 01:27 - 26 Apr 2025 20:01 #327069
by langdons
Deleted.
- Thank you received: 7181
26 Apr 2025 12:48 #327082
Replied by tommylight on topic spindle with encoder
1% of 360 is 3.6 degree of error, and that will result in broken taps.
- langdons
26 Apr 2025 20:00 #327098
by langdons
I see.
I suppose this is a low-speed spindle?
(not 10000RPM)
(not 10000RPM)
- langdons
26 Apr 2025 20:05 #327100
by langdons
Isn't the spindle RPM selected exactly by the VFD?
A 3-phase motor does not lose steps.
The spindle starts before the tap is in contact with the work, correct?Just wait a second after the motor starts before reading RPM from encoder.
This would not work with rigid tapping (the OP's question)
- Thank you received: 5106
26 Apr 2025 20:18 #327101
Replied by PCW on topic spindle with encoder
I think maybe you don't understand how rigid tapping works.
When rigid tapping, the Z axis motion is synchronized (geared basically)
to the spindle rotation, the synchronized motion is continuous through
the downstroke, spindle reversal and upstroke. Any pause that interferes
with this "gearing" will break taps.
- vre
- Thank you received: 17
27 Apr 2025 06:29 #327128
by vre
Replied by vre on topic spindle with encoder
rigid tapping needs reversal of spindle so backlash matters.
If i have encoder on spindle shaft backlash
will be problem?
How many lines encoder needed for rigid tapping?
will be problem?
- langdons
27 Apr 2025 13:30 #327154
by langdons
For more than 1 line, you should buy a precision-made encoder wheel to ensiure accuracy.
- vre
28 Apr 2025 16:37 #327222
by vre
Why if i put in spindle shaft an aluminum disk with 2x100 holes(pi/2 equally spaced for A-
and 1 hole for index drilled on the same mill?
I think i can do holes 1-1.5mm in the same mill accurately.
28 Apr 2025 16:56 - 28 Apr 2025 22:22 #327223
Typically you just have one track of holes and the B detector offset from the A detector by
hole_pitch*(N+1/4). That is, if the holes were 2 mm apart, the A/B detectors would be
spaced .50 MM or 2.50 mm or 4.50 mm etc.
This 1/4 pitch offset gives you the desired 90 degree phase difference between A and B.
Note the when drilling holes you should aim for a 50% duty cycle waveform
on A and B. This may require some experimentation and changing the sensors
radial positions.
radial positions.
Last edit: 28 Apr 2025 22:22 by PCW.
Time to create page: 0.081 seconds
