Spindle speed?
- TheTinkeringMechanic1
- Thank you received: 5
01 Aug 2025 18:24 #332635
by TheTinkeringMechanic1
Replied by TheTinkeringMechanic1 on topic Spindle speed?
Alright. Finally back on this project. The control appears to come from computer to a mesa 7187 to the VFD. The forward and reverse commands from the board go into STF and STR to command direction. Pins 2 (input) 5 (analog common). In forward the voltage ramps up and down as commanded through the gui and shows rpm in the bar. But in reverse the voltage to the VFD stays the same. If I switch forward and reverse command wires in the VFD they simply act in opposite. This eliminates the VFD as the issue. I need to find out why Linux isn't controlling the voltage to the VFD in reverse and also why it's not displaying reverse RPM in the GUI.
- Thank you received: 5314
01 Aug 2025 18:39 #332636
Replied by PCW on topic Spindle speed?
You probably mean a 7I83 or 7I77 (the 7I87 is an analog _input_ card)
My guess is that there is a missing abs function in the hal file.
The 7I83 and 7I77 have bipolar +-10V analog outputs, but most VFDs
only take a unipolar ( typically 0 to +10V) input range, so you either need to
use the absolute spindle speed pin from motion or add an abs function
if you have an old enough LinuxCNC version that does not have the absolute
spindle speed pin.
spindle speed pin.
01 Aug 2025 18:49 #332637
Upon closer inspection, it is 7i83. I'll get a flashlight next time. How can I tell if the version I have is too old? (LinuxCNC 3.4.6) Furthermore, can I update it?
01 Aug 2025 18:52 #332638
Can you post your hal/ini files?
01 Aug 2025 18:54 #332639
They were posted earlier in this thread. Not much has changed since then.
01 Aug 2025 19:15 - 01 Aug 2025 19:35 #332640
If you look at the hal file, none of the important spindle connections
actually connect to anything, that is, the hi-lighted signal names are
not connected to any driving source.
EDIT: can you post the other hal files? I suspect the missing
connections are there.
HALFILE = Knuth.hal
HALFILE = 6i24.hal
HALFILE = LadderIO.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
Also using halshow to watch hm2_5i24.0.7i83.0.2.analogout0
when running the spindle in each direction would help debug this
HALFILE = Knuth.hal
HALFILE = 6i24.hal
Last edit: 01 Aug 2025 19:35 by PCW.
01 Aug 2025 19:35 #332641
Unfortunately, I got the lovely task of coming in behind somebody else and I need to figure it out. I knew nothing of Linux prior to a month ago, but I'm a fast learner. This has had me stumped for quite some time. If you could point me towards some documentation or if you could give some guidance on how to accomplish what is needed, that would be greatly appreciated.
01 Aug 2025 20:12 #332642
Is there something specific you are looking for? There are a myriad of back up files stored in here.
01 Aug 2025 20:17 #332643
Looking into halshow now.
01 Aug 2025 20:41 #332644
You posted Knuth.hal but not:
6i24.hal
LadderIO.hal
custom.hal
custom_postgui.hal
These are all parts of the configuration
6i24.hal
LadderIO.hal
custom.hal
custom_postgui.hal
Time to create page: 1.670 seconds
