From a quick glance, there is no home switch assigned for Y2, so that will not work, as you describe above is not the normal tandem axis/joint behavior, normal is : no jogging possible for tandem axis before homing.... i got it to where machine will turn on and respond to jog, however i cannot have Y and Y2 work together i can run them individually.
