NEW BUILD, need help with e-stop in tklinuxcnc
1 year 3 weeks ago #336186
by Dragan
NEW BUILD, need help with e-stop in tklinuxcnc was created by Dragan
For weeks, I've been working on my own CNC machine and have made good progress, but I need help with some small details from experts.The machine is a MicroCarve MV3 with 3x 23-305-DS8A steppers in bipolar parallel mode, connected to a TB6600, which is connected to a Raspberry Pi 4. I don’t have a stop button yet.I’ve managed to wire the motors and Pi to test the axes with a Python script. I also created a minimalist INI and HAL file and started TkLinuxCNC. However, I can’t move the motors because the software shows an E-stop, and despite my efforts, I can’t get the machine to move.I access the Pi via VNC without a connected monitor. The image used is rpi-4-debian-bookworm-6.1.54-rt15-arm64-ext4-2023-11-17-1731.img.xz, updated to LinuxCNC 2.9.6.Friends, I need help. I’ve spent many hours on this and am close to getting the machine running.My test script works; HAL and INI files are attached.Thanks,
Dragan
Dragan
- Thank you received: 1480
1 year 3 weeks ago #336188
Replied by Todd Zuercher on topic NEW BUILD, need help with e-stop in tklinuxcnc
If your test machine has no external e-stop circuit you shouild simply connect the e-stop out signal to the estop in signal in your hal file. Something like this:
net estop-in => iocontrol.0.emc-enable-in
Then the e-stop buttons on the userinterface will work. and you will need to toggle them when starting Linuxcnc.
1 year 3 weeks ago #336202
by Dragan
Replied by Dragan on topic NEW BUILD, need help with e-stop in tklinuxcnc
thank you for the quick answer it is not working i tried everything its super strange.
1 year 3 weeks ago #336205
Replied by Aciera on topic NEW BUILD, need help with e-stop in tklinuxcnc
Have you clicked on the 'ESTOP' button in the tklinuxcnc gui to set 'Estop off' and 'Machine on'?
1 year 3 weeks ago #336206
by Dragan
i did and its not working, when i start sim tklinuxcnc its working
1 year 3 weeks ago #336208
If you select 'Utilities' > 'HalMeter' in the tklinux menu and select 'iocontrol.0.emc-enable-in' does it show TRUE ?
Time to create page: 0.237 seconds
