NEW BUILD, need help with e-stop in tklinuxcnc
10 Oct 2025 20:30 - 10 Oct 2025 20:32 #336227 by PCW
if this:
net estop-loop =>iocontrol.0.user-enable-out
net estop-loop => iocontrol.0.emc-enable-in
does not work, it's most likely because you have
estop-loop connected to another pin in the hal file.
Starting LinuxCNC from the command line will show the actual error.
Last edit: 10 Oct 2025 20:32 by PCW.
10 Oct 2025 20:37 #336229 by Dragan
c@raspberrypi:~/linuxcnc/configs/microcarve$ LINUXCNC - 2.9.6
Machine configuration directory is '/home/cnc/linuxcnc/configs/microcarve'
Machine configuration file is 'microcarve.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./microcarve.hal
task: main loop took 0.100768 seconds
task: main loop took 0.113741 seconds
task: main loop took 0.140260 seconds
this is what i get running it from commandline. task: main loop ........
10 Oct 2025 20:41 #336231 by PCW
Are you saying the GUI never launches?
10 Oct 2025 20:45 #336232 by Dragan
gui is launching i cant move the stepper with arrows because i am locked and i can not turn the machine on
10 Oct 2025 20:51 #336233 by andypugh
Replied by andypugh on topic NEW BUILD, need help with e-stop in tklinuxcnc
Does the sim/tklinuxcnc config start OK? That uses the same loop.
github.com/LinuxCNC/linuxcnc/blob/master...lib/core_sim.hal#L46
11 Oct 2025 08:52 #336268 by Dragan
Hello friends, thanks to everyone for the help. Unfortunately, it didn't work out, and after two days, I gave up and looked for another solution. I stumbled across an Arduino in my boxes and decided to go with UGS on Raspberry (VNC) & GRBL on Arduino. Everything worked flawlessly right away. I'm satisfied. Thanks again to all and best wishes.
Thanks,
Dragan
Time to create page: 0.135 seconds
