NEW BUILD, need help with e-stop in tklinuxcnc
1 year 3 weeks ago #336209 by Dragan
1 year 3 weeks ago #336223 by andypugh
net estop-out =>iocontrol.0.user-enable-out
net estop-in => iocontrol.0.emc-enable-in
I think these need to be the same signal name to work as described. Try:
net estop-loop =>iocontrol.0.user-enable-out net estop-loop => iocontrol.0.emc-enable-in
(note that the signal name is nothing special, there is no significance in changing it to loop, other than clarity. The important thing is that it should be the same name on both lines)
1 year 3 weeks ago #336224 by andypugh
Oh, and why tklinuxcnc? There's nothing wrong with it, but it's rather outmoded and hasn't had a lot of developer attention for a while.
1 year 3 weeks ago #336225 by Dragan
axis not working over vnc in my setup,
this is resulting in tklinuxcnc not starting, maybe its working with older software versions.
1 year 3 weeks ago - 1 year 3 weeks ago #336227 by PCW
if this:
does not work, it's most likely because you have
estop-loop connected to another pin in the hal file.
Starting LinuxCNC from the command line will show the actual error.
Last edit: 1 year 3 weeks ago by PCW.
1 year 3 weeks ago #336229 by Dragan
c@raspberrypi:~/linuxcnc/configs/microcarve$ LINUXCNC - 2.9.6
Machine configuration directory is '/home/cnc/linuxcnc/configs/microcarve'
Machine configuration file is 'microcarve.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./microcarve.hal
task: main loop took 0.100768 seconds
task: main loop took 0.113741 seconds
task: main loop took 0.140260 seconds
this is what i get running it from commandline. task: main loop ........
Time to create page: 0.251 seconds
