Mesa 6i25 - Mesa 7i76U - Omron MX2 wiring
- Ozcnc
08 Feb 2026 03:21 - 08 Feb 2026 05:26 #342631
by Ozcnc
Mesa 6i25 - Mesa 7i76U - Omron MX2 wiring was created by Ozcnc
Hello,Im using LinuxCNC 2.9Can I please get some assistance with wiring of the mesa 7i76U to an omron mx2 VFD and the HAL and INI file and the correct firmware recommendation. files.omron.eu/downloads/latest/manual/e...rs_manual_en.pdf?v=1
You do not have permissions to access this page.
Last edit: 08 Feb 2026 05:26 by Ozcnc. Reason: added picture
- Thank you received: 5323
08 Feb 2026 06:12 #342633
Replied by PCW on topic Mesa 6i25 - Mesa 7i76U - Omron MX2 wiring
Here is 5I25/6I25 firmware for a 7I76U with the PKTUART
I can try to help more later, but note there is another user trying to get a Omron MX2
working with a Mesa card and having issues. I suspect I may have to acquire a MX2
to try and get this going.
The 7I76U manual has the RS-485 wiring information (and you must use RS-485 mode with the 7I76U
so you lose on estep/dir output)
- Ozcnc
08 Feb 2026 09:56 #342644
by Ozcnc
Replied by Ozcnc on topic Mesa 6i25 - Mesa 7i76U - Omron MX2 wiring
Ok thank you I'm happy to use the RS-485 mode,
- Ozcnc
27 Apr 2026 11:24 #345971
by Ozcnc
Hello,
Hope you are well,
I have bought a 7i76EU and would like to know if you have any specific firmware I should use.
My setup is Linuxcnc 2.9.7, VFD is Omron MX2 and I will connect this using the RS-485 mode. Other config details, I am using 5 Gecko Stepper Drives driving X1,X2 Y, Z and A rotary axis. I don't have any encoders.
All Jumpers are default and I have a unregulated power supply that I can connect to the board.
Can you also confirm if a CAT5 cable or higher speed cable is required.
Thank you.
Kind Regards,
Orrin
Hope you are well,
Thank you.
Kind Regards,
Orrin
27 Apr 2026 16:28 #345989
7i76eu_7i76x1_pktv3d.bin
or
7i76eu_7i76x1_pktv2d.bin
For older LinuxCNC distributions
or
The following user(s) said Thank You: Ozcnc
- charlieLedezma
06 Aug 2026 01:59 #348479
by charlieLedezma
Replied by charlieLedezma on topic Mesa 6i25 - Mesa 7i76U - Omron MX2 wiring
Hi, PCW
Is there available firmware, for the configuration: 7i92 + 7i76U_pktv3d.bin ?
I need to use the modbus characteristics of 7i76U
Thanks, in advance.
Thanks, in advance.
06 Aug 2026 02:17 - 06 Aug 2026 02:17 #348481
No, but I can make one tomorrow.
7I92 or 7I92T?
7I92 or 7I92T?
Last edit: 06 Aug 2026 02:17 by PCW.
06 Aug 2026 23:09 #348509
7I92 and 7I92T firmware for 7I76U with PKTUART/RS-485:
06 Aug 2026 23:13 #348510
The correct firmware is this:
Sorry that was the wrong firmware for a 5I25/6I25 --> 7I76U using RS-485 modeHere is 5I25/6I25 firmware for a 7I76U with the PKTUART
- charlieLedezma
20 Aug 2026 15:14 #348879
by charlieLedezma
Time to create page: 0.176 seconds
