LinuxCNC on 12.04...got error, what does it mean?
- greenbuggy
04 May 2013 02:43 #33595
by greenbuggy
LinuxCNC on 12.04...got error, what does it mean? was created by greenbuggy
I was getting a few unexpected realtime errors while tuning my system on 10.04 and read that Xenomai and 12.04 works better on newer processors and mainboards so I updated to 12.04LTS and followed the instructions here:
www.anderswallin.net/2012/12/linuxcnc-on-ubuntu-12-04lts/
to get Xenomai and synaptic on my system
Now when I attempted to start linuxCNC it tries to start then I get this error in my linuxcnc_debut.txt
This in my linuxcnc_print.txt:
I've attached my config files. Machine is running on a WTM D28 mobo with an Intel Atom 1.8, 2G ram, 500 GB HDD, Mesa 5i20-PCI.
I'm fairly new to linux so I'm not sure exactly what I did wrong here, or how to go about fixing it.
If its beyond fixing or better to do a fresh install of Ubuntu 12.04 then xenomai and compiling LinuxCNC I can do that, and don't mind being told that I should go back to 10.04 but I'm curious what I did wrong such that linuxCNC won't start, so I can learn from my mistakes. Thanks for the help.
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
26699
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
RUN_IN_PLACE=yes
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/home/kris/emc2-dev/bin
LINUXCNC_TCL_DIR=/home/kris/emc2-dev/tcl
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/home/kris/emc2-dev/rtlib
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/home/kris/emc2-dev/src/objects
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
INIFILE=/home/kris/linuxcnc/configs/Lagun/Lagun.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Killing task linuxcncsvr, PID=26699
- ArcEye
- Thank you received: 758
04 May 2013 17:32 #33599
by ArcEye
Replied by ArcEye on topic LinuxCNC on 12.04...got error, what does it mean?
Hi
Unfortunately from those little snippets of error messages can't tell anything.
You need to run from a terminal and post all the output plus that from the /var/logs/kern.log
For info though, 10.04 runs very well on Intel Atoms, has some of the lowest latency figures you will find for newer boards. (typically sub 10K sometimes down to 5K)
Xenomai and 12.04 runs better on my quad core machine than 10.04 and the stock rtai kernel did, but Xenomai runs horrendously on a P4 I tested on
So it is not a silver bullet, there are horses for courses
- greenbuggy
05 May 2013 02:30 #33616
by greenbuggy
Replied by greenbuggy on topic LinuxCNC on 12.04...got error, what does it mean?
OK then try this:
- greenbuggy
05 May 2013 02:34 - 05 May 2013 02:55 #33617
by greenbuggy
and kern.log - split in two
Last edit: 05 May 2013 02:55 by greenbuggy.
- greenbuggy
05 May 2013 02:55 - 05 May 2013 05:49 #33620
by greenbuggy
kern. log pt 1 of 2
Last edit: 05 May 2013 05:49 by greenbuggy.
- greenbuggy
05 May 2013 05:54 #33628
by greenbuggy
Third try is the charm maybe....BTW Moderators "editing" and adding a file doesn't seem to be working
- BigJohnT
- Thank you received: 1175
05 May 2013 18:24 #33648
by BigJohnT
Replied by BigJohnT on topic LinuxCNC on 12.04...got error, what does it mean?
Only some file extensions are allowed... see using this forum for the list.
- ArcEye
05 May 2013 18:46 #33649
by ArcEye
Hi
From what little info there is at present I suspect your build is the problem.
Either the libraries are not built properly to be dynamically loaded or , because you have built in your home directory, there is no path to them in the environment.
You can either build with -rpath=/path/to/library/ or try to do it afterwards by adding the path to LD_LIBRARY_PATH and / or add the paths to ~/.bashrc
Look up that error message in google for more info
dlopen error: ......../hal_lib.so: cannot open shared object file: No such file or directory
- tiffany
04 Dec 2013 12:11 #41328
by tiffany
Replied by tiffany on topic LinuxCNC on 12.04...got error, what does it mean?
I have the same debug information as yours. could you tell me what 's wrong about it?
thank you!
thank you!
- Thank you received: 4966
04 Dec 2013 17:38 #41336
Was this a liveCD installation, or something built from source?
Replied by andypugh on topic LinuxCNC on 12.04...got error, what does it mean?
thank you!
Time to create page: 0.106 seconds
