LinuxCNC on 12.04...got error, what does it mean?
- skunkworks
- Thank you received: 154
wiki.linuxcnc.org/cgi-bin/wiki.pl?NewRTInstall
Another refferance is here - I put all the build dependencies on this page that I needed.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Mesa7i..._Linuxcnc_On_Xenomai
remember to add the user to the right groups. (explains on the first link)
- ddmotim
linuxcnc_print:
RUN_IN_PLACE=yes
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/home/minibox/linuxcnc-rtos/bin
LINUXCNC_TCL_DIR=/home/minibox/linuxcnc-rtos/tcl
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/home/minibox/linuxcnc-rtos/rtlib
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/home/minibox/linuxcnc-rtos/src/objects
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
INIFILE=/home/minibox/linuxcnc-rtos/configs/Bridget/Bridget.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Killing task linuxcncsvr, PID=21498
linuxcnc_debug:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
21498
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
I'll try again and post all of the output from the terminal
- ArcEye
- Thank you received: 758
21498
This is not the cause, but a symptom - occurs quite often.
Will need the full error print and anything relevant from the end of dmesg.
If you can run a specimen config, the problem is in your own config, which I assume ran under an earlier version, not this one.
Try a comparison between the .hal and .ini files from the specimen and your old config. If that does not jump out at you, zip your config folder and attach it along with the errors
- ddmotim
Nothing jumps out at me from my config files.
Also worth noting, once I try my config file and it fails, I cannot run the gecko config either.
- ArcEye
You are right, it does have something to do with the parport
Starting LinuxCNC...
config string '0x378 out '
Failed to claim parallel port /dev/parport0
hal_parport: rtapi_app_main: -19
From dmesg
[3.813109] parport_pc 00:09: reported by Plug and Play ACPI
[3.813176] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTA
[3.907328] lp0: using parport0 (interrupt-driven).
[610.369632] parport0: cannot grant exclusive access for device ppdev0
I assume you are using a normal distro of 12.04, so it is assumed that you will want to print stuff and lp is loaded at boot (plus parport_pc and ppdev)
These block hal_parport_pc and Lcnc cannot access the parport
Before running run
sudo rmmod ppdev
sudo rmmod parport_pc
sudo rmmod lp
in a terminal
You should then be able to run OK
Thereafter you can remove the lp line in /etc/modules to prevent it loading at boot
(it may not be there in 12.04, will need to rummage around a bit)
It will just have screwed up the module unloads, should run fine after a reboot
- ddmotim
- ddmotim
- ArcEye
parport_pc is in the dependency chain for lp.
You need to find where lp is being loaded and stop it at boot
The standard method was to create a file called /etc/modprobe.d/linuxcnc.conf, which contains
install parport_pc /bin/true
and to comment out the line in /etc/modules
lp
I noticed you have the cups daemon loaded too, don't know if that tries to initiate lp, but you don't need it so that can go too
The entries in /etc/rc1.d to rc5.d are what I mean, but if you are not comfortable with that level of hacking, just leave them
- ddmotim
I've got lp commented out in /etc/modules.
I created /etc/modprobe.d/linuxcnc.conf.
After reboot, if I run lsmod | grep lp, lp still shows up. Any recommendations on how to figure out what is loading it?
I ran
sudo rmmod ppdev
sudo rmmod lp
and got no errors this time. But now when I run linuxcnc, the error says it couldn't find the device at address 0x378
- ArcEye
Unfortunately I don't have a 12.04 partition on a machine with a parport, so hard to experiment myself.
The whole system changed post 2.6.2X kernels, with far more emphasis upon hardware detection and udev creating devices on the fly
I would suspect that udev is loading lp when the port is discovered at boot and then it creates /dev/lp0 and /dev/parport0
The problem is that in /lib/modules/${uname -r}/modules.dep there will be a dependency chain which loads parport_pc and thence ppdev
It is parport_pc that is the problem.
If lp is now being loaded by udev, it is likely that when it is removed, udev also removes the /dev/lp0 and /dev/parport0 it created and linuxcnc will report that it cannot find the port at 0x378
So try booting and then dmesg | grep parport && dmesg | grep ppdev && dmesg | grep lp
If either parport_pc or ppdev are there then remove them, but leave lp and try linuxcnc again
