LinuxCNC on 12.04...got error, what does it mean?
- ddmotim
08 Jan 2014 00:17 #42441
by ddmotim
I tried this, and still no luck. I tried looking deeper into the file system, and I broke something...
I also realized something that made me feel a little stupid...I had installed Lubuntu not just Ubuntu, so I'm guessing that may have something to do with it.
So I did a fresh install of Ubuntu and started over. Now I seem to be having a problem loading any realtime kernel. Following the same documents as before, I couldn't get Xenomai to run. While looking for answers to that, I came across the new RTAI kernel and figured I'd give it a shot: wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_On_Ubuntu_Precise
With the RTAI build, I can't get the kernel to load on boot. I changed the grub config file to force the rtai kernel to load on boot, and it came up with the blue memory test screen. I tried again, and looked into the lib directory, and it seems like there are files missing from the rtai kernel directory.
I'm doing a side by side of two Ubuntu 12.04 installs so I can try to figure out one or the other (xenomai or RTAI).
I can't seem to find anyone else who has successfully installed the RTAI
Replied by ddmotim on topic LinuxCNC on 12.04...got error, what does it mean?
So try booting and then dmesg | grep parport && dmesg | grep ppdev && dmesg | grep lp
If either parport_pc or ppdev are there then remove them, but leave lp and try linuxcnc again
- ddmotim
08 Jan 2014 00:32 #42443
by ddmotim
Looking through the printout, I noticed this. I get the same thing for the RTAI install
Hmm. There is a symbolic link /lib/modules/3.5.7-xenomai-2.6.2.1/build
However, I can not read it: No such file or directory
Therefore, I am deleting /lib/modules/3.5.7-xenomai-2.6.2.1/build
Hmm. The package shipped with a symbolic link /lib/modules/3.5.7-xenomai-2.6.2.1/source
However, I can not read the target: No such file or directory
Therefore, I am deleting /lib/modules/3.5.7-xenomai-2.6.2.1/source
- ArcEye
- Thank you received: 758
08 Jan 2014 01:00 #42445
by ArcEye
That is not important, it just means that the modules were created when the kernel sources were available, which those 2 symlinks would have pointed to
I am running 3.5.7-rtai now, but on Debian and I compiled it all myself from sources
birchy has tried those packages I think ( wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_On_Ubuntu_Precise)
www.linuxcnc.org/index.php/english/forum...blems?start=20#42158
He got a kernel panic on one lot and 6 figure latency on the other, so he is now compiling the 3.5.7-rtai from the same source code that I used.
I'll take it that the parport issue is on hold until you get up and running again
Replied by ArcEye on topic LinuxCNC on 12.04...got error, what does it mean?
Hmm. There is a symbolic link /lib/modules/3.5.7-xenomai-2.6.2.1/build However, I can not read it: No such file or directory Therefore, I am deleting /lib/modules/3.5.7-xenomai-2.6.2.1/build Hmm. The package shipped with a symbolic link /lib/modules/3.5.7-xenomai-2.6.2.1/source However, I can not read the target: No such file or directory Therefore, I am deleting /lib/modules/3.5.7-xenomai-2.6.2.1/source
Time to create page: 0.111 seconds
