Error while running linuxcnc simulator
12 Jan 2014 05:10 #42629 by uberlinux
Error while running linuxcnc simulator was created by uberlinux
I am using debian 7 with lxde and i just want simulator i followed instruction from wiki Also what are leftover files that i can delete and create a deb for my class mate to use it as simulator , but i tried using libgl1-mesa-swx11-dev but it still doesnt work
12 Jan 2014 17:51 #42639 by emcPT
Replied by emcPT on topic Error while running linuxcnc simulator
The most straight forward approach is to download the CD, and install it.Give it a try then continue from there.
12 Jan 2014 18:35 #42642 by uberlinux
Replied by uberlinux on topic Error while running linuxcnc simulator
i am sorry i didnt mention that i was able to run low graphic version , but whenever i try to run lathe or any of that version it would run show linux cnc splash and shutdown the terminal immediately
12 Jan 2014 21:10 #42652 by ArcEye
Replied by ArcEye on topic Error while running linuxcnc simulator
Hi
It sounds like a problem with GLX / Open GL , but unless you post the full errors and the end of dmesg output, we can't really help
The following user(s) said Thank You: uberlinux
13 Jan 2014 00:26 #42660 by uberlinux
i have attached dmesg
13 Jan 2014 01:28 #42663 by ArcEye
Hi
I can't see anything from those.
Looks like you have a SandyBridge chipset, are using the i915 video driver, which is perfectly capable of displaying openGL, I used one until very recently.
You are either using a laptop or have a USB camera permanantly plugged in, if the latter I would remove it
There is nothing in dmesg, if there was a SEGFAULT etc there normally would be.
Try running it from a terminal and capture the error messages and use the axis_mm sim not the axis_9axis sim
What exactly did you run that worked?
Can you run glxgears OK?
13 Jan 2014 01:39 - 13 Jan 2014 01:57 #42664 by uberlinux
i was able to run tklinuxcnc and xlinuxcnc also glxgears worked fine
Last edit: 13 Jan 2014 01:57 by uberlinux.
13 Jan 2014 02:31 #42665 by ArcEye
OK
Tends to point to openGL, which is obviously why you tried the software library.
Await the full error messages
13 Jan 2014 03:42 - 13 Jan 2014 03:44 #42666 by uberlinux
Here are the logs ,and thanks for helping a noob like me :lol:
Last edit: 13 Jan 2014 03:44 by uberlinux.
13 Jan 2014 05:18 #42672 by phillc54
Time to create page: 0.287 seconds
