Compile RTAI kernel 3.4-9-rtai-686 on deb.wheezy
30 Oct 2014 18:20 #52572 by ww34ww34
I clean all.
I crate two virtual machine.
1) linuxcnc debian.hybrid.iso
2) fresh debian 7.6.0
I use your github link
github.com/ArcEye/3.4.55-rtai
I compile in both the kernel
with a little issue fixed with
cd /usr/src/linux
sed -i s/CONFIG_RTS5139=m/CONFIG_RTS5139=n/ .config
And the two machine start correctly.
But when i run RTAI compilation i have on the two machine this error
/usr/src/RTAI$ sudo make menuconfig
/bin/sh: 0: Can't open /base/config/kconfig/lxdialog/check-lxdialog.sh
/bin/sh: 0: Can't open /base/config/kconfig/check.sh
make[1]: *** [dochecklxdialog] Error 127
make: *** [menuconfig] Error 2
i try to make /base/config/kconfig/lxdialog/check-lxdialog.sh executable but nothing change.
It's really hard.
Thanks.
regars
30 Oct 2014 18:25 #52573 by ww34ww34
If i try without sudo
/usr/src/RTAI$ make menuconfig
 *** Unable to find the ncurses libraries or the
 *** required header files.
 *** 'make menuconfig' requires the ncurses libraries.
 *** Install ncurses (ncurses-devel) and try again.
but i install all ncurses lib
I attached the result of
dpkg --get-selections
30 Oct 2014 18:49 - 30 Oct 2014 19:38 #52575 by ArcEye
Have you done all the steps as per the README in the repo?
You need to run autogen.sh, run ./configure and then make menuconfig, because the Makefile does not exist until you do
$ cd /usr/src/RTAI && ./autogen.sh && ./configure && make menuconfig
Otherwise I can only assume this is something with you trying to compile on virtual machines instead of on the actual machine.
You will have to explain exactly what you mean by a virtual machine, even chroot can fail if the base system and the one which you chroot to do not match
(eg one is amd64 and the other i386)
libncurses5:amd64 install
libncurses5-dev install
libncursesw5:amd64 install
You also seem to be trying to compile on an amd64 build, which is not what the repo or kernel config is for
Last edit: 30 Oct 2014 19:38 by ArcEye.
30 Oct 2014 20:47 #52583 by ww34ww34
Yes.All in order.
Yes too
I have two 64bit istance of virtualBox running under windows 7. (Vbox ver.4.3.18)
I dont' know why this lib was installed for amd64.
Maybe your build has inside something related to your amd64 system?
Now i'm trying with a new virtual machine on Vmware.
My new pc is coming from amazon. Then I can try on a real machine.
Thanks.
regards.
30 Oct 2014 21:00 #52585 by ArcEye
Don't understand that, the quote was from your installed packages, not mine
The package list I gave you was platform agnostic, it will download the version of the package which fits your platform.
If I had realised you were trying to build using VMWare from a windoze machine, I would have given up a long time ago.
Just install the debian.hybrid.iso on a real computer and build on that computer.
It is quite straight forward
31 Oct 2014 18:21 #52616 by ww34ww34
Hi.
Sorry. I just try with virtual machines for test on varius environnement.
But now i do all the process on a real machine.
Same issue.
I attached the history log file from installation until now.
thanks.
01 Nov 2014 00:01 #52626 by ArcEye
Hi
Having seen the log, I think the problem is that you have switched from building as root, to building as a user with sudo.
The RTAI dir is owned by root, so there is probably some foul up going on there
Just revert back to the repo and fetch your own copy instead of using mine
git clone github.com/SebKuzminsky/rtai/ /usr/src/RTAI
cd /usr/src/rtai
git checkout old-3.9-debs
That hopefully will solve it
01 Nov 2014 01:03 #52631 by ww34ww34
I solved this problem with
$ sudo -i
 ~ # cd /usr/src/linux
 # make menuconfig
Now I'm going foreward. I'll keep you updated.
Thanks.
regards.
08 Nov 2014 18:22 #52939 by ww34ww34
Ok. I've done.
I try this script on two virtual machine (fresh and linuxcnc.hybrid.iso) and with little modification it work and also i definitely try on a real machine all work.
I leave here the code that worked for me for anyone we'll be so crazy to compile all from 0...like me :laugh:
sudo apt-get install gedit git-core libncurses5 libncurses5-dev  dh-autoreconf libboost-python1.49-dev libboost-python1.49.0 build-essential debhelper kernel-package libpth-dev libgtk2.0-dev tcl8.5-dev tk8.5-dev bwidget python-old-doctools python-tk python-dev libglu1-mesa-dev libgtk2.0-dev libgnomeprintui2.2-dev libncurses5-dev libxaw7-dev gettext libreadline-gplv2-dev lyx texlive-extra-utils imagemagick texinfo groff libmodbus-dev libudev-dev libmodbus-dev libboost-python-dev libboost-serialization-dev libboost-thread-dev libtk-img automake autoconf libtool libusb-dev automake1.11 libtool python-setuptools libusb-1.0-0-dev
mkdir ArcEye-dev
git clone https://github.com/ArcEye/3.4.55-rtai ArcEye-dev
sudo cp -Rv ArcEye-dev/linux-3.4.55 /usr/src/linux-3.4.55
sudo ln -sfv  /usr/src/linux-3.4.55 /usr/src/linux
sudo cp -Rv ArcEye-dev/.config /usr/src/linux/.config
sudo cp ArcEye-dev/hal-linux-3.4.55-x86-1.patch /usr/src/
cd /usr/src/linux/
sudo patch -p1 < ../hal-linux-3.4.55-x86-1.patch
sudo -i
cd /usr/src/linux/
make clean
make menuconfig
make -j$(cat /proc/cpuinfo | grep processor | wc -l)
make modules_install install
make install
/sbin/reboot
git clone https://github.com/SebKuzminsky/rtai/ /usr/src/RTAI
cd /usr/src/RTAI
./autogen.sh
./configure
make menuconfig
make
make install
/sbin/reboot
cd /usr/src
git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev
cd /usr/src/linuxcnc-dev/src
./autogen.sh
./configure
make
make setuid
cd ../
. ./scripts/rip-enviroment
Thanks ArcEye. Great work.
08 Nov 2014 19:30 #52940 by ArcEye
Well done, now you just have to see if Atom optimisation actually improves the latency etc.
You have earned your membership to the club for people stupid enough to build their own kernels B)
Time to create page: 0.133 seconds
