Debian uspace and 7i80
- mariusl
16 Mar 2015 23:40 #56894
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Debian uspace and 7i80
Pings are still around 100us. I assume you are referring to the modules in the config string of hm2. That would be helpful once I get the 7i80 to talk back to hm2. I still have no luck with that and I have no idea how to debug the problem either.
I am a bit frustrated with myself at the moment and I only have the one box to use for this job.
Regards
Marius
www.bluearccnc.com
- Thank you received: 5021
17 Mar 2015 00:31 #56896
Replied by PCW on topic Debian uspace and 7i80
I would try
1. trimming the number of modules used in the driver config line
2. if that doesnt work, lower the servo thread rate
3. posting your hal/ini files here may help
- mariusl
17 Mar 2015 02:31 #56897
by mariusl
Regards
Marius
www.bluearccnc.com
I have halved the servo rate to 2000000ns
I made the modules one each
And I am using the example (7i92) that you provided on the mailing list
Regards
Marius
www.bluearccnc.com
- mariusl
17 Mar 2015 02:37 #56898
by mariusl
Regards
Marius
www.bluearccnc.com
What I dont understand here is if the MAC address is read from the FPGA then how can the rest not be received? I dont understand the deeper workings of the code but that seems strange to me.
Is there a way for me to try an debug this somehow. I am just guessing now and I dont even know the name of the game
Regards
Marius
www.bluearccnc.com
- mariusl
17 Mar 2015 03:15 #56899
by mariusl
Regards
Marius
www.bluearccnc.com
The first value sent to the board is 0x5d88. Is that what is expected when the board is probed. I also put a long timeout in the code to see if that is a problem but it does not help.
It does not answer back on that command.
Regards
Marius
www.bluearccnc.com
17 Mar 2015 04:09 - 17 Mar 2015 04:10 #56903
Just checked with a D525 (similar CPU horsepower but older chipset) and hm2_eth runs OK at 1 KHz on it
Possibly there's a network setup issue of some kind. maybe disabling the iptables filter
will help if theres some issue there.
It might possibly be a problem with old (or maybe strange set of modules) firmware in the 7I80
(I dont think there were any versions that have serious bugs, but I haven't used any old firmware for a while)
You can determine the firmware features and version with mesaflash
Last edit: 17 Mar 2015 04:10 by PCW.
- mariusl
17 Mar 2015 14:07 - 17 Mar 2015 14:36 #56913
by mariusl
Regards
Marius
www.bluearccnc.com
There might be a problem here. I could see the board before with mesaflash as I reprogrammed the ip to 10.10.10.10. The board will answer a ping to that address but now the mesaflash also reports that it cannot find a 7i80 board. Even if I enter the new ip in the command line.
The jumpers are
W1 - down
W2 - up
W3 - up
W4 - up
I connected with the board on the default ip but I cannot seem to find the firmware version number. I did a readhmid. Where should I look for the firmware version?
The jumpers are
W1 - down
W2 - up
W3 - up
W4 - up
Regards
Marius
www.bluearccnc.com
Last edit: 17 Mar 2015 14:36 by mariusl.
- mariusl
17 Mar 2015 14:50 - 17 Mar 2015 14:59 #56916
by mariusl
Regards
Marius
www.bluearccnc.com
I can see the board on ip 10.10.10.10.
The manual has an error on page 13 where it states that the command line option is -ip xx.xx.xx.xx. This should be --addr xx.xx.xx.xx.
I still cannot find the firmware version.
Output of of readhmid attached
Regards
Marius
www.bluearccnc.com
Last edit: 17 Mar 2015 14:59 by mariusl.
17 Mar 2015 23:34 #56953
you can get the Ethernet firmware version with mesaflash's --verbose option:
mesaflash --device 7i80 --addr 10.10.10.10 --verbose
the -addr option used to be --ip I will update the manual
Did you try disabling the iptables filter? a mistake here might disable all communication to the 7I80 when linuxcnc is started
- mariusl
18 Mar 2015 01:04 #56955
by mariusl
Regards
Marius
www.bluearccnc.com
Hi Peter
I did remove the iptables entries in the rules.v4 file. No change there.
I attached the output of the verbose option
Regards
Marius
www.bluearccnc.com
Time to create page: 0.207 seconds
