linuxcnc on 64bit OS
- grandixximo
- Thank you received: 10
26 May 2015 09:12 - 26 May 2015 09:14 #59055
by grandixximo
linuxcnc on 64bit OS was created by grandixximo
I'm trying to have linuxcnc work on 64bit ubuntu 14.04
Why 64bit?
Because Draftsight releases packages only for 64bit systems, and i need draftsight to work on the same machine with linuxcnc.
Why Ubuntu?
Ease of use, and install (ditch unity and install gnome classic for a familiar look), i guess Debian would work too, but i haven't much experience with it.
I have seen on another post they linked this github.com/NTULINUX/RTAI
But i need to build myself a Kernel, and i don't have the required skills to configure it.
Any suggestions, or kernel configurations i can use?
Anyone has some already made packages that would work on 64bit systmes?
Or a live CD with 64bit linux OS?
Does linuxcnc has any plans to move to 64bit in the future?
Why 64bit?
Why Ubuntu?
Last edit: 26 May 2015 09:14 by grandixximo.
- ArcEye
- Thank you received: 758
26 May 2015 15:07 #59062
by ArcEye
Replied by ArcEye on topic linuxcnc on 64bit OS
Linuxcnc will build on a rt-preempt 64 bit kernel with uspace configured.
If you are using servos or hardware step generation, that should work.
Debian Wheezy has a stock rt-preempt kernel available as a package, there is not one for Jessie yet, but I built my own and am running it now.
If you need a rtai kernel, then only Machinekit has packaged amd64 kernels immediately available with realtime packages.
There is a 3.8.1-amd64-rtai image for debian 7 and 8 and Ubuntu 14
The problem will be how the maths functions are dealt with.
When developing the Machinekit kernels and realtime, we eventually ended up using libposemath, which was originally for Xenomai.
Linuxcnc does things differently and I suspect still may not build on the Machinekit realtime.
That is why NTULINUX was promoting his repo for RTAI, it supposedly has the maths issue sorted in a way that supports Linuxcnc.
The alternative of course is to use Machinekit , but I couldn't possibly promote that on this forum.
- grandixximo
26 May 2015 15:17 - 26 May 2015 21:10 #59063
by grandixximo
Replied by grandixximo on topic linuxcnc on 64bit OS
i don't need very low latency on my system, 50000 or 100000 ns are enough, i use mesa cards to control the servos.
I'm going to try with Debian Wheezy 64Bit, install the stock RT-PREEMPT and see if i can build LinuxCNC on it.
Do you know which branch can i build on it?
Should i try unified-build-candidate-3?
Last edit: 26 May 2015 21:10 by grandixximo.
- ArcEye
26 May 2015 17:28 #59067
by ArcEye
Just build the master with configure set as per this wiki
wiki.linuxcnc.org/cgi-bin/wiki.pl?Uspace
It is simple, I used it for ages, just recently switched to Jessie and a home brew kernel.
That is defunct, other than what was copied from it to do uspace.
ubc-3 became Machinekit, because the Linuxcnc developers would not include it in the next release so @mhaberler forked it and it has developed completely seperately since.
i don't need very low latency 50000 or 100000 ns are enough, i use mesa cards to control the servos.
The following user(s) said Thank You: grandixximo
- ArcEye
26 May 2015 17:44 #59070
by ArcEye
PS
If you are running a real machine on rt_preempt, don't be tempted to install proprietary video drivers, just because you want to use it for CAD too.
This machine has a 2GB GPU Nvidia card, which works perfectly using the opensource nouveau drivers.
If I build the nvidia drivers via DKMS, I will get a RTAI error every time realtime starts
- mozmck
- Thank you received: 58
26 May 2015 19:39 #59073
by mozmck
Replied by mozmck on topic linuxcnc on 64bit OS
AFAIK, the only Mesa hardware that works with rt_preempt is the ethernet hardware, so if you are not using an ethernet board you need RTAI
- grandixximo
26 May 2015 19:51 #59074
by grandixximo
why would that be the case?
Are you sure?
The hostmot driver doesn't work with rt-preeemt?
Are you sure?
- grandixximo
26 May 2015 20:23 #59077
by grandixximo
According to this
Hardware support
The following drivers are built and tested:
hm2_pci (tested with 5i20, 5i25, 5i22)
So it should work...
Well i'll try tomorrow, ad let you know guys, thanks for your help!
Hardware support
- Thank you received: 5213
26 May 2015 20:27 #59078
Replied by PCW on topic linuxcnc on 64bit OS
Uspace/Preemt-RT works with our PCI cards, I dont recall testing the EPP cards (7I43/7I90HD)
- grandixximo
26 May 2015 21:09 #59080
by grandixximo
What gpu are you using?
I won't built proprietary drivers, but if it can improve cad performance with the open source drivers, without rtai error, that would be awesomeness, what GPU is it?
I tried a bunch of gpu with old Ubuntu 10.04 live CD installation, but I never could find a suitable one.
The rt-preempt is more forgiving?
I can install any GPU?
Nvidia or ati?
PS
Nvidia or ati?
