linuxcnc on 64bit OS
- ArcEye
- Thank you received: 758
28 May 2015 20:44 #59154
by ArcEye
Good.
rt1 is very early, PCWs scripts pull rt7 I think and I have built rt10 recently
You may find a later rt version more stable and lower latency still, a lot depends upon the computer really, as to how well rt-preempt runs on it, but yours seems OK.
see how you get on
Replied by ArcEye on topic linuxcnc on 64bit OS
BTW i did not try the debian kernel, but i have been sucessfull with the kernel provided here
bitbucket.org/thismaechler/ubuntustudio-14.04-realtimeaudio/
3.18.7-rt1
Good.
see how you get on
The following user(s) said Thank You: grandixximo
- Thank you received: 5203
29 May 2015 04:06 #59171
Replied by PCW on topic linuxcnc on 64bit OS
Here's a script for building 3.18.13-rt10
cd ~
mkdir rtlinux
cd rtlinux
wget ftp://ftp.kernel.org/pub/linux/kernel/v3.x/linux-3.18.13.tar.xz
wget www.kernel.org/pub/linux/kernel/projects....18.13-rt10.patch.gz
tar -xpf linux-3.18.13.tar.xz
gunzip patch-3.18.13-rt10.patch.gz
cp patch-3.18.13-rt10.patch linux-3.18.13
cd linux-3.18.13
cat patch-3.18.13-rt10.patch | patch -p1
sudo apt-get install libqt4-dev
make xconfig
make -j2
sudo make modules_install
sudo make install
Note that you may want to trim a lot of uneeded drivers
perhaps by running "make localmodconfig" before make xconfig
if you expect the kernel/drivers to only run on the compile system
cd ~
mkdir rtlinux
cd rtlinux
cd linux-3.18.13
make xconfig
make -j2
sudo make install
- grandixximo
- Thank you received: 10
29 May 2015 15:48 #59182
by grandixximo
Replied by grandixximo on topic linuxcnc on 64bit OS
Thank you so much.
I have been able to build the kernel and install it, and build Linuxcnc on it
Thank you for all your help
Time to create page: 0.095 seconds
