linuxcnc on 64bit OS
26 May 2015 21:19 #59081 by mozmck
Replied by mozmck on topic linuxcnc on 64bit OS
Ok, I had heard wrong about Preempt-RT - sorry about that.
As far as GPUs, I had a lenovo with an ATI/AMD card (not sure which model) and it made the latency really bad using preempt-rt. The on-board video worked fine and latency was great after taking the ATI card out.
So I don't know how other cards will work, but that was my experience with one card.
The following user(s) said Thank You: grandixximo
26 May 2015 22:33 #59083 by ArcEye
Replied by ArcEye on topic linuxcnc on 64bit OS
PS
If you are running a real machine on rt_preempt, don't be tempted to install proprietary video drivers, just because you want to use it for CAD too.
This machine has a 2GB GPU Nvidia card, which works perfectly using the opensource nouveau drivers.
If I build the nvidia drivers via DKMS, I will get a RTAI error every time realtime starts
What gpu are you using?
I won't built proprietary drivers, but if it can improve cad performance with the open source drivers, without rtai error, that would be awesomeness, what GPU is it?
I tried a bunch of gpu with old Ubuntu 10.04 live CD installation, but I never could find a suitable one.
The rt-preempt is more forgiving?
I can install any GPU?
Nvidia or ati?
This machine is just for development, not controlling a cnc machine.
The card was bought for gaming ( its a GT650 I think ), quite honestly for CAD a normal video chip is fine unless you are doing a lot of 3D modelling or something like that.
I don't really know about other cards with rt-preempt, so would be hesitant to recommend anything, but it certainly will not be more forgiving, you are skating along the edge of
acceptable performance with rt-preempt and anything like that can push it over that edge.
26 May 2015 23:59 - 27 May 2015 02:36 #59085 by PCW
Replied by PCW on topic linuxcnc on 64bit OS
Well... if you are using decent modern hardware, Preemt-RT performance can be quite good:
freeby.mesanet.com/h97-g3258-preemt-rt.png
Note this is using built in (in CPU) Intel Graphics I have not needed nor used a GPU in a long time
Last edit: 27 May 2015 02:36 by PCW.
  • grandixximo
  • grandixximo's Avatar Topic Author
  • Premium Member
  • Premium Member
27 May 2015 12:10 #59098 by grandixximo
Replied by grandixximo on topic linuxcnc on 64bit OS
Thank you guys for all your help,
Unfortunatly Draftsight does not open up in wheezy :sick:
GLIBC_2.15 required, i installed it according to this forum.mepiscommunity.org/viewtopic.php?f=88&t=37022
but the preformance are very very sloppy with the insternal graphics :sick:
Mouse movements are late, haven't installed rt kernel yet.
On ubuntu 14.04 CAD performance on same machine are pretty good...
I'm going to try Jessie, see if CAD performance are good on it, if they are i guess i'll wait for the official rt kernel, any idea when that will be available?
27 May 2015 13:14 #59102 by ArcEye
I'll wait for the official rt kernel, any idea when that will be available?
Machinekit have been pestering a guy called Nick at Debian to provide an official package for Jessie.
Sounds like it will happen, but when......?
27 May 2015 22:11 - 27 May 2015 22:15 #59112 by PCW
I think preemt-rt 4.0.4-rt1 has just been added to the debian repositories
www.spinics.net/lists/linux-rt-users/msg13416.html
note, I found 4.04.rt1 to have quite poor latency relative to 3.18.13-rt10
(the latest previous preemt-rt kernel), at least on one test machine
so it may take a while for the 4.xx branch to stabilize
Last edit: 27 May 2015 22:15 by PCW.
The following user(s) said Thank You: ArcEye
27 May 2015 23:20 #59114 by ArcEye
Thanks for that
Would have taken a while for that list post to permeate out into the search engines.
I am on 3.18.13-rt10 at present, so will stick with it until I hear better reports.
Looks like 4.xx will be the starting point, so no 3.8.xx rt kernels in packages though?
  • grandixximo
  • Premium Member
  • Premium Member
28 May 2015 11:49 - 28 May 2015 12:00 #59142 by grandixximo
Draftsight does not seem to agree with Debian Jessie either :sick:
I guess i'm back to Ubuntu 14.04
You guys think the debian preempt kernel will work on ubuntu?
packages.debian.org/wheezy/linux-image-rt-amd64
this one?
Ubuntu 14 comes with kernel 3.16 i think, this is 3.2 can it work?
I'll try and report back, if that won't work, any other already built kernels i can use?
Last edit: 28 May 2015 12:00 by grandixximo.
28 May 2015 15:15 #59143 by ArcEye
Possible, but perhaps unlikely
It is quite trivial to build a rt-prempt kernel compared to rtai plus realtime
PCW even posted links to instruction scripts here
www.linuxcnc.org/index.php/english/forum...l-h81?start=20#58548
Just install the package build-essential and give it a go
(you will need to go into make menuconfig and change the first option to 64 bit on the config, but other than that you can leave it as it is)
  • grandixximo
  • Premium Member
  • Premium Member
28 May 2015 19:51 #59153 by grandixximo
Thank you so much!
I will try to build my own preempt kernel
BTW i did not try the debian kernel, but i have been sucessfull with the kernel provided here
bitbucket.org/thismaechler/ubuntustudio-14.04-realtimeaudio/
3.18.7-rt1
i'm seeing decent latency with latency-test around 20000, which is better than what i expected, and Linuxcnc is not sending the RTAI error with
SERVO_PERIOD = 75000
which, i think is decent enough, not for stepping, but good enough to run with a Mesa card
I will try to build a fresher kernel see how things go, i am quite happy with the results i see so far, thank you so much for all your help :)
Time to create page: 0.072 seconds
