Upgrade 2.5 to 2.6 and to 2.7,nothing works
- gaston48
- Online
- Thank you received: 5
25 Sep 2015 19:20 - 25 Sep 2015 20:09 #62972
by gaston48
Upgrade 2.5 to 2.6 and to 2.7,nothing works was created by gaston48
Hello everyone
I'm running Ubuntu Lucid with Athlon64
I upgraded my version 2.5 which was very good
to 2.6 and nothing works
then to 2.7 nothing works too.
here: the messages Error
an idea ?
thank you a lot !
an idea ?
thank you a lot !
Last edit: 25 Sep 2015 20:09 by gaston48.
- seb_kuzminsky
- Thank you received: 14
25 Sep 2015 21:39 #62988
by seb_kuzminsky
Replied by seb_kuzminsky on topic Upgrade 2.5 to 2.6 and to 2.7,nothing works
Hi there, sorry you're having trouble. Your configurations should work (Ubuntu Lucid, RTAI, LinuxCNC 2.5, 2.6, and 2.7), so we just need to figure out where things went wrong and fix it.
How did you do the upgrade from 2.5 to 2.6? From 2.6 to 2.7?
Can you supply the output from the following commands, for debugging:
dpkg -l 'linuxcnc*'
dpkg --audit
debsums -c linuxcnc
Thanks!
dpkg -l 'linuxcnc*'
dpkg --audit
debsums -c linuxcnc
Thanks!
- gaston48
- Online
25 Sep 2015 21:58 #62990
by gaston48
Replied by gaston48 on topic Upgrade 2.5 to 2.6 and to 2.7,nothing works
Thank you very much for your quick response
and sorry for my English google
Meanwhile I returned to 2.5.4 and everything works again perfectly !!!
For updates to 2.5 to 2.6 and to 2.7 I have exactly followed the
instructions in linuxcnc.org:
Update: "source software"
then update "Synaptic Package Manager"
Question: for your debugging control "dpkg "
I have to reinstall 2.6.9 or 2.7.0 ?
Thanks!
Thanks!
- seb_kuzminsky
25 Sep 2015 22:54 #62992
by seb_kuzminsky
I just installed LinuxCNC using the 2.5 Install Image (Ubuntu Lucid, RTAI, LinuxCNC 2.5), then upgraded to 2.6 using the
instructions on the wiki
, and verified that the sim/axis/axis config ran. I then upgraded to 2.7 using
these instructions
, and again ran that config, and everything went well.
So I think the packages are fine, and the install process works, and something else must have gone wrong with your upgrades, or something is special about your system that affects the upgrade.
Please install 2.6 and run those commands that I asked for earlier.
- gaston48
- Online
26 Sep 2015 00:06 - 26 Sep 2015 00:27 #62994
by gaston48
Last edit: 26 Sep 2015 00:27 by gaston48.
- seb_kuzminsky
26 Sep 2015 02:28 #63000
by seb_kuzminsky
It's strange that the problem is in /usr/lib/python2.6/dist-packages/linuxcnc.so, since that's not one of the files that the linuxcnc debian package installs. Maybe at some point you built from source and then ran "make install"?
Try this:
dpkg -S /usr/lib/python2.6/dist-packages/linuxcnc.so
dpkg -S /usr/lib/pyshared/python2.6/linuxcnc.so
Try this:
- gaston48
- Online
26 Sep 2015 03:12 - 26 Sep 2015 03:27 #63004
by gaston48
Last edit: 26 Sep 2015 03:27 by gaston48.
- seb_kuzminsky
26 Sep 2015 03:39 #63007
by seb_kuzminsky
Are there any old emc packages around? Try "dpkg -l emc*".
There shouldn't be, they should have been automatically removed when you installed linuxcnc 2.5.
But in any case we know that no debian package claims the erroneous file that's causing all the trouble. I don't know where it came from, but you could try removing it by hand. There may be other stray files around that can cause similar problems later, if so you should consider doing a re-install to get rid of them all (but make sure you save/backup your configs and other personal files first).
- gaston48
- Online
26 Sep 2015 03:53 - 26 Sep 2015 04:14 #63008
by gaston48
if i did a new install, i would do with Debian wheezy ?
Last edit: 26 Sep 2015 04:14 by gaston48.
- seb_kuzminsky
26 Sep 2015 04:41 #63009
by seb_kuzminsky
Thanks for all your debugging attachments. They show that your system has the right packages installed, plus the mystery linuxcnc.so in the wrong place that's breaking your upgrade.
I ran "make install" in our 2.5 branch (with the -n flag, so it didnt actually copy anything), and it wanted to place linuxcnc.so in /usr/lib/python2.6/dist-packages, exactly where yours is. I think someone (maybe not you) ran "make install" at some point, and that's why upgrades are broken for you now.
I think your options are to try to remove the accidentally installed non-package files by hand, or wipe your system and reinstall. We are deep in dangerous territory now, but this shell script will run for a long time and then show all files in /usr that are not owned by any debian package on your system. You could try removing them all and see if that makes things better. I'd opt for a reinstall myself.
for F in $(find /usr -type f) ; do dpkg -S $F > /dev/null ; done
Time to create page: 0.158 seconds
