Good bye to Ubuntu 10.04
09 Nov 2016 09:20 - 09 Nov 2016 09:23 #82603 by bkt
Replied by bkt on topic Good bye to Ubuntu 10.04
The same for me...
As a side note ( mental ), i would love the 10.04 with updated stuff, same desktop and 2.8pre running on it.
Unity It is cumbersome over gnome to customize (or mate or xfce) .... but personally I'm used to work on unity and are now able to find it even functional ... (for LinuxCNC must create all the launcher by hand and save them as .desktop ... then depending on the job you can also turn into style icons gnome ubuntu 10.04 on the screen ..)
Now I try to envelope somethings in android like qtvcp (but I not use qtvcp only android and java) as remote gui for Lcnc... for my part Remote Qt Gui is just do (in these period I test my custom uspace comp for work with it... if test go ok i upload it to forum) .. surely android+java is more difficult then customize unity.....
SUrely the ubuntu direction actually is Qt ... so some legal noise about re-distribution there is ... but in the future we will Andoid our supreme commander ?? ;)
I am very sorry to bid farewell to Ubuntu 10.04 :unsure: :( ... it was very nice to LCNC .... but now I'm in love with Ubuntu 04.14 (course for now I can not use it to LCNC) ... and I suspect I will like it also 16:04 ....
Regards
Giorgio
Last edit: 09 Nov 2016 09:23 by bkt.
09 Nov 2016 14:30 #82608 by PCW
Replied by PCW on topic Good bye to Ubuntu 10.04
Actually Ubuntu 14.04 (and the derivative Mint 17) work fine with LinuxCNC,
Ubuntu 16.04 (and Mint 18) also work but have a few minor issues (mostly fixed in master)
The following user(s) said Thank You: bkt
09 Nov 2016 15:31 #82610 by bkt
ohh well done ... so I can use your (@PCW) 6i25 or E7i76 on 14.04 using the master version ?? and with that kernel rtai ??
Regards
giorgio
09 Nov 2016 15:48 #82611 by PCW
Any of Mesas PCI/PCIE/Ethernet cards work fine with 2.7.x or master on 14.04
I would not bother with RTAI unless you are using a parallel port and software stepping
Its much easier to get modern hardware support via a Preempt-RT kernel
(though if you have older hardware I would stay with a 4.1.xx or lower kernel version)
09 Nov 2016 17:13 #82620 by bkt
sorry but my ultimate reading is these:
precise install
& these ..
14.04 patch
what did I miss? because you tell me that I can Please install with a preempt-rt ... it is available in the repo for Ubuntu 4.14? .. For work in real time & for sim? Master (JA completed) and 2.7.7 ??
Sorry I read nothing about !! can you send me some links about??
Regards
giorgio
09 Nov 2016 17:23 - 09 Nov 2016 17:26 #82624 by PCW
I just installed a standard ubuntu 14.04 (same with Mint 17 and Mint 18)
then compiled/installed a Preempt-RT kernel and compiled LinuxCNC from source
Last edit: 09 Nov 2016 17:26 by PCW.
09 Nov 2016 19:24 #82625 by jtc
Replied by jtc on topic Good bye to Ubuntu 10.04
its the same process to install on ubuntu 16?
09 Nov 2016 20:21 #82627 by PCW
Yes, same process. there are some minor issues with 16.04/Mint18
There's a setuid issue with 16.04 and Mint18 that causes trouble
with Ethernet cards ( something related to not getting root permissions to launch iptables )
I think this is only fixed in master
There's also a python numpy fix needed for 16.04/Mint18 but this has been added to 2.7.8
(but not added to master yet AFAIK)
Also for some reason Axis starts up minimized in Mint18. probably a window manager issue
The following user(s) said Thank You: jtc
10 Nov 2016 09:07 #82641 by lincamx
Replied by lincamx on topic Good bye to Ubuntu 10.04
has opensuse been consider, I think that the use of the suse build studio would make it easy and slick to build a linuxcnc Appliance.
10 Nov 2016 11:05 #82645 by tommylight
Replied by tommylight on topic Good bye to Ubuntu 10.04
I gave up on suse when they got bought by novel and novel sold the rights to microsoft for using linux modules in windows . I had to use novel for over 3 years ( job requirement ) and it was a total mess. Do not even get me started on windoze.
Then again suse was quite nice at that time. Pitty.
Time to create page: 0.133 seconds
