Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
8 years 6 months ago #108918 by dbanks
8 years 6 months ago - 8 years 6 months ago #108920 by dbanks
installed qt 4.8 as it said it needed it. running make -j8 came back saying recipe for target scripts failed. How awful is my luck here.
found a solution for me: $ sudo apt-get install python-pip python-dev libffi-dev libssl-dev libxml2-dev libxslt1-dev libjpeg8-dev zlib1g-dev
Last edit: 8 years 6 months ago by dbanks.
8 years 6 months ago #108922 by dbanks
So it's finished its compiling and installing at the install without deb step. Since i have the preempt kernel, i skip the install with deb and rtai steps and move on to the reboot right?
8 years 6 months ago #108929 by rodw
dbanks wrote: So it's finished its compiling and installing at the install without deb step. Since i have the preempt kernel, i skip the install with deb and rtai steps and move on to the reboot right?
I've never installed the debs, just run in place from the command prompt by typing linuxcnc. You always have to run the . ./scripts/rip-environment script to set up all of the environment variables. Check the docs for syntax as the initial '.' is important.
8 years 6 months ago #108941 by andypugh
You don't need the debs.
In fact if you are running with the preempt-rt kernel (you can test this with ename -a ) then you probably didn't need to compile LinuxCNC either.
buildbot.linuxcnc.org/
(Though I don't see a Xenial version, so perhaps you did)
8 years 6 months ago #108951 by dbanks
When selecting the kernel, I get a VFS Unable to mount root fs error now.
Time to create page: 0.209 seconds
