- LinuxCNC
- Installing LinuxCNC
- Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
- shortcircuit48
- Thank you received: 3
18 Feb 2018 20:55 #106152
by shortcircuit48
Replied by shortcircuit48 on topic Compnclete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
I now have
hamish@hamish-Presario-CQ57-Notebook-PC ~/linuxcnc-dev $ dpkg-checkbuilddeps
dpkg-checkbuilddeps: error: Unmet build dependencies: docbook-xsl yapps2
- cncnoob1979
- Thank you received: 75
18 Feb 2018 23:07 - 18 Feb 2018 23:08 #106159
by cncnoob1979
Replied by cncnoob1979 on topic Compnclete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Hamish,
You'll have to find them in the repos. Look at the first few post and you can find the website/repo to find those.
When installing it will be
sudo apt-get install xxx (yaps2, ect...)
And look for a dependency for docbook-xsl.
Let me know if you can not find them.
Last edit: 18 Feb 2018 23:08 by cncnoob1979.
The following user(s) said Thank You: shortcircuit48
- shortcircuit48
19 Feb 2018 19:02 #106179
by shortcircuit48
I have to really thank you for your patience with me. Programme is now up and running
When I get the welcome screen and select a configuration the programme does not start full screen but only shows on the very bottom title bar, one click brings it full screen. Will look into laptop set up as it may be there.
Does not really mean much to me, but ran a latency test and it is horrendous, suggesting this laptop will be useless for actual control but will allow me to learn.
Thanks again for your help
- cncnoob1979
19 Feb 2018 20:41 #106186
by cncnoob1979
You're welcome.
A laptop is ok to learn with but not to run a controller. So when you get the process down pat you will be ready for the real install.
A laptop will not work because of the latency induced from power saving features.
- RothMetalWorks
07 Mar 2018 02:08 - 07 Mar 2018 14:34 #107065
by RothMetalWorks
Replied by RothMetalWorks on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Hello, I'm installing this on a Touchsmart 9100 and got thru the kernel build. I installed the .deb's and everything I could. The only files left were txt and .gz. It didn't seem like it updated the boot loader though, it finished pretty quick. I installed grub customizer and moved the 4.9.4 kernel to the top. After I rebooted it came up in failsafe mode. I rebooted again and now it starts loading Mint 18.3 and then starts beeping with a black screen.
Grub only lists my hard drive and no kernels so I'm not sure what to do now.
Any suggestions?
I'm using Post 2 on the first page to install.
Thanks!
Mike
Any suggestions?
Thanks!
Mike
Last edit: 07 Mar 2018 14:34 by RothMetalWorks.
- RothMetalWorks
07 Mar 2018 21:45 #107097
by RothMetalWorks
I was just able to change to the original kernel after pressing shift.
Any idea what I could have missed it did wrong to have it crash like that?
- bkt
- Thank you received: 114
15 Mar 2018 12:01 #107370
by bkt
Replied by bkt on topic Compnclete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
For first thanks for your work ...
I do not always follow the forum or mailing list so I completely lost my progress on ubuntu / mint 64bit and RTAI. .... The 4.x kernel version that you say about Kuminzky corresponds to the RTAI 5.1 version + adaptations made by kuminzky for LCNC? In any case, despite being a version dev. does he work on a real robot (scara / puma / delta) or is it just sim?
I wrote here because my question on mailing list is missing.
giorgio
giorgio
- cromaglious
05 Apr 2018 18:19 #108460
by cromaglious
Replied by cromaglious on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Anyone run into this as well? Any ideas? XmuLookupStandardColormap error
Linux vescnc 4.14.18-rt15 #1 SMP PREEMPT RT Wed Feb 14 14:11:27 PST 2018 x86_64 x86_64 x86_64 GNU/Linux
Mint 18.1
model name : AMD GX-415GA SOC with Radeon(tm) HD Graphics
quad core
8GB RAM 2TB HD Dell Wyse Thin client Zx0Q Ethernet + Wifi -- no parallel Looking to run with 7i92M + 7i76 X1
EDIT ADDED IN FROM THE START OF THE COMMAND LINE:
ves@vescnc ~/linuxcnc-dev/debian $ linuxcnc
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/ves/linuxcnc-dev/configs/sim/axis'
Machine configuration file is 'axis.ini'
Starting LinuxCNC...
Found file(lib): /home/ves/linuxcnc-dev/lib/hallib/core_sim.hal
Note: Using POSIX realtime
Found file(lib): /home/ves/linuxcnc-dev/lib/hallib/sim_spindle_encoder.hal
Found file(lib): /home/ves/linuxcnc-dev/lib/hallib/axis_manualtoolchange.hal
Found file(lib): /home/ves/linuxcnc-dev/lib/hallib/simulated_home.hal
Found file(lib): /home/ves/linuxcnc-dev/lib/hallib/check_xyz_constraints.hal
File "/home/ves/linuxcnc-dev/bin/axis", line 60, in <module>
from rs274.OpenGLTk import *
File "/home/ves/linuxcnc-dev/lib/python/rs274/OpenGLTk.py", line 17, in <module>
import _togl
ImportError: /home/ves/linuxcnc-dev/lib/python/_togl.so: undefined symbol: XmuLookupStandardColormap
link (updating variable file): No such file or directory
task: 573 cycles, min=0.000042, max=0.002076, avg=0.001050, 0 latency excursions (> 10x expected cycle time of 0.001000s)
Mint 18.1
quad core
import _togl
- cncnoob1979
08 Apr 2018 23:33 #108637
by cncnoob1979
Replied by cncnoob1979 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
K-1,
I don't know if he is running a robot or not. Sorry maybe someone else can chime in and tell us.
cromagilous,
Did you have any missing dependencies?
Is this the latest master version? Looks like you are running a sim Hal. But you are in realtime so at lest the kernel is good.
Have you tried looking at the last import .hal before the error?
cromagilous,
- dbanks
12 Apr 2018 02:42 #108866
by dbanks
Replied by dbanks on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
My entering of the long code at post 4 rendered being unable to locate Tcl18.6-dev, tk8.6-dev. First line of the Kernel install wget resulted in unable to resolve host address. Didn't try the patch following given that not working. Couldn't continue from there, assuming it all stacked on itself. Any ideas?
- LinuxCNC
Time to create page: 0.377 seconds
