Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
12 Apr 2018 21:38 #108906 by dbanks
Turns out I know even less than I thought I did. haha
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
12 Apr 2018 21:38 #108907 by ozzyrob
sys/types.h should be in the build essential package. Did you install that package ?
12 Apr 2018 21:54 #108909 by dbanks
Running a sudo apt-get upgrade in hopes of that fixing the problem. It's been doing a lot of stuff.
12 Apr 2018 22:17 #108916 by dbanks
I followed all of the steps in order, is there something I missed?
12 Apr 2018 22:31 #108918 by dbanks
12 Apr 2018 22:47 - 12 Apr 2018 23:08 #108920 by dbanks
installed qt 4.8 as it said it needed it. running make -j8 came back saying recipe for target scripts failed. How awful is my luck here.
found a solution for me: $ sudo apt-get install python-pip python-dev libffi-dev libssl-dev libxml2-dev libxslt1-dev libjpeg8-dev zlib1g-dev
Last edit: 12 Apr 2018 23:08 by dbanks.
13 Apr 2018 01:13 #108922 by dbanks
So it's finished its compiling and installing at the install without deb step. Since i have the preempt kernel, i skip the install with deb and rtai steps and move on to the reboot right?
13 Apr 2018 04:12 #108929 by rodw
I've never installed the debs, just run in place from the command prompt by typing linuxcnc. You always have to run the . ./scripts/rip-environment script to set up all of the environment variables. Check the docs for syntax as the initial '.' is important.
13 Apr 2018 12:26 #108941 by andypugh
You don't need the debs.
In fact if you are running with the preempt-rt kernel (you can test this with ename -a ) then you probably didn't need to compile LinuxCNC either.
buildbot.linuxcnc.org/
(Though I don't see a Xenial version, so perhaps you did)
13 Apr 2018 16:43 #108951 by dbanks
When selecting the kernel, I get a VFS Unable to mount root fs error now.
Time to create page: 1.317 seconds
