Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
8 years 4 months ago #112470 by tecno
bengt@CNC3000 ~/linuxcnc-dev/debian $ sudo apt-get update [sudo] lösenord för bengt: Bra:1 http://archive.canonical.com/ubuntu xenial InRelease Ign:2 http://buildbot.linuxcnc.org precise InRelease Läs:3 http://buildbot.linuxcnc.org precise Release [58,3 kB] Läs:4 http://buildbot.linuxcnc.org precise Release.gpg [490 B] Bra:5 http://archive.ubuntu.com/ubuntu xenial InRelease Läs:6 http://archive.ubuntu.com/ubuntu xenial-updates InRelease [109 kB] Läs:7 http://archive.ubuntu.com/ubuntu xenial-backports InRelease [107 kB] Läs:8 http://archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages [795 kB] Läs:9 http://archive.ubuntu.com/ubuntu xenial-updates/main i386 Packages [728 kB] Läs:10 http://archive.ubuntu.com/ubuntu xenial-updates/universe amd64 Packages [636 kB] Läs:11 http://archive.ubuntu.com/ubuntu xenial-updates/universe i386 Packages [580 kB] Läs:12 http://security.ubuntu.com/ubuntu xenial-security InRelease [107 kB] Bra:13 http://ppa.launchpad.net/danielrichter2007/grub-customizer/ubuntu xenial InRelease Ign:14 http://packages.linuxmint.com sylvia InRelease Bra:15 http://packages.linuxmint.com sylvia Release Hämtade 3 121 kB på 20s (150 kB/s) Läser paketlistor… Färdig bengt@CNC3000 ~/linuxcnc-dev/debian $ ./configure uspace noauto Package libxenomai-dev exists, but information about its source package is not available. This most likely means that you do not have the right deb-src lines in /etc/apt, or that you need to "apt-get update". bengt@CNC3000 ~/linuxcnc-dev/debian $ ./configure uspace Package libxenomai-dev exists, but information about its source package is not available. This most likely means that you do not have the right deb-src lines in /etc/apt, or that you need to "apt-get update". bengt@CNC3000 ~/linuxcnc-dev/debian $
  • ozzyrob
  • New Member
  • New Member
8 years 4 months ago #112471 by ozzyrob
After enabling the source code repos you should have the other file as mentioned before.
8 years 4 months ago #112472 by tecno
This is what i have, been following the instructions as good as I can.
Not so easy for a ½blind bloody foreigner LOL
  • ozzyrob
  • New Member
  • New Member
8 years 4 months ago - 8 years 4 months ago #112473 by ozzyrob
So did you enable the source code repositories thru Package Manager ?
Which branch of linuxcnc did you checkout 2.7 or master ?
Master has some differences in the hal files.
I'm just a "Dumb Aussie" called Murphy ;)
If you have trouble with adding the source code repos the Linux Mint forums might be the place to try.......just ask about adding source code repositories.
Last edit: 8 years 4 months ago by ozzyrob.
8 years 4 months ago #112474 by tecno
ozzyrob wrote: So did you enable the source code repositories thru Package Manager ?
Enable what files = been following this thread thats all
Just got RT working and trying to get 2.7.13 installed and here I am with no-go
So not interested in master for now until I get this PC on the road with Mint or something else but not Debian Stretch as it will not work with this PC.
Why does it have to so bloody painful to get Linux to work ;)
8 years 4 months ago #112477 by tecno
successfully configured for 'uspace-LinuxMint-18.3'-'uspace'.. bengt@CNC3000 ~/linuxcnc-dev/debian $ cd .. bengt@CNC3000 ~/linuxcnc-dev $ dpkg-checkbuilddeps dpkg-checkbuilddeps: fel: Unmet build dependencies: docbook-xsl intltool bengt@CNC3000 ~/linuxcnc-dev $
How to cure that ?
Time to create page: 0.540 seconds
