Mitsubishi SSCNET
3 years 10 months ago #258586 by Aciera
Replied by Aciera on topic Mitsubishi SSCNET
I'm wondering what the original controller did to drive the two carriages independently since I suppose everything came out of the same Gcode. A lot of it was probably handled in the CAM but it certainly seems that you would need two independent linuxcnc installations with the gcode for some of the axes passed over from one to the other with some sort of synchronization.
Thanks for posting. I'm looking forward to see what you come up with.
3 years 10 months ago #258590 by dm17ry
Replied by dm17ry on topic Mitsubishi SSCNET
afaik, mitsubishi controllers have a "system" entity. i belive it's an independent g-code interpreter+interpolator. for this machine has
system $0: Z1,X1,V
system $1: Z2 X2
system $2 ??? aux functions - workpiece removal
spindles are shared
i don;t have yet a programming manual for the traub, i'll try to obtain one. i guess they have 2 g-code programs running simultaneously plus some means of synchronization between them
3 years 10 months ago - 3 years 10 months ago #258591 by dm17ry
there's also a fanuc robot on the photo in the background - i may try to get on it too ;)
Last edit: 3 years 10 months ago by dm17ry.
3 years 10 months ago #258595 by Aciera
Awsome! Lot's to look forward to.
3 years 10 months ago #258651 by andypugh
Replied by andypugh on topic Mitsubishi SSCNET
LinuxCNC can use absolute encoders, you know....
3 years 10 months ago #258667 by dm17ry
yes, i know. :) but i still use them my own way: a patch to add "joint.x.set-homed" pins and saving motor-offset to the .pos file...
Time to create page: 0.065 seconds
