Mitsubishi SSCNET
6 years 5 months ago - 6 years 5 months ago #166990 by drdyna
Replied by drdyna on topic Mitsubishi SSCNET
Do you know anything about the older protocol? I mean obviously it'll be different at the hardware level if the old bus is parallel and the new bus is serial, but are the commands or packet structures similar at all?
I need to fix some mechanical things on the machine before I'm ready to dive into doing anything with the bus anyway.
Also I looked up the bus in the manuals I have - 50 pins, all in pairs (not sure if they're differential signalling or not - probably). I thought some manual had at least a rough pinout, but all I could find was a basic cable spec.
Last edit: 6 years 5 months ago by drdyna.
6 years 5 months ago - 6 years 5 months ago #166993 by dm17ry
Replied by dm17ry on topic Mitsubishi SSCNET
unfortunately no, i haven't tried to hack the MR-S... no idea about the protocol. c'mon, those drives are 30 years old... ;)
i'd be surprised it the protocol is similar to the newer drives. from my experience with reverse engineering, mitsubishi changes everything with each new version. unless you have a somewhat working control to snoop on the bus or a lot of time to disassemble and understand the drive firmware - i wouldn't try to resurrect them. would be more practical to replace drives/motors with something more modern. imho :)
Last edit: 6 years 5 months ago by dm17ry.
6 years 5 months ago #167079 by drdyna
I do have a working control - everything works, I'd just like to modernize the machine. I'll throw a logic analyzer on the bus in the next while and see what it looks like.
Everytime I see people retrofit and replace everything, the machine seems to always end up slower and worse than it originally was. Not to mention the expense of new servos, encoders, and controllers, when the originals work just fine.
6 years 5 months ago #167135 by dm17ry
i've found CN1A/CN1B connectors pinout. looks like a multiplexed address/data bus with a few extra signals. if you have a running system shouldn't be too hard to reverse engineer...
6 years 5 months ago - 6 years 5 months ago #168224 by Hamada
Replied by Hamada on topic Mitsubishi SSCNET
Hi Dmitry
I am looking for help to be able to run YSSC2P with 2.8.0nyx9 ~ pre1 (PREEMPT_RT / stretch)
Board was installed to PCI slot and Amber Led is showing "long off/short on" (firmware is standing by). When I start Linuxcnc with SSCII configuration but it is showing error as attached report
I installed OS and sscii driver as following:
1. install Debian Stretch
2. Upgrade to Linuxcnc 2.8 RT Preempt
3. Install package from link : yurtaev.com/files/linuxcnc-uspace_2.8.0nyx9-pre1/
File Name: linuxcnc-report.txt
File Size:5.23 KB
Hamada
Last edit: 6 years 5 months ago by Hamada.
6 years 5 months ago - 6 years 5 months ago #168710 by dm17ry
oh, i'm sorry, just noticed your message
i stopped updating the sscii driver module long ago and it only exists in wheezy/RTAI build. to run the card in stretch/buster with PREEMPT_RT kernel you need to update the firmware to v2 and use the 'nyx' module instead. please, contact me via email and i will give links and instructions
Time to create page: 0.076 seconds
