Mitsubishi SSCNET
8 years 7 months ago #107481 by Henk
Replied by Henk on topic Mitsubishi SSCNET
Great news! Looking forward to hear from you.
Henk
8 years 6 months ago #108720 by wu-010@163.com
Replied by wu-010@163.com on topic Mitsubishi SSCNET
I hope we can use MR-J4W2 series servo soon. This kind of servo make easier to handle double y-axies.
8 years 6 months ago #108724 by dm17ry
Replied by dm17ry on topic Mitsubishi SSCNET
i also hope... it's been a long time :)
meanwhile, i've got the basic spindle support finished. verified on MDS-B-SPH: initial parameters upload, velocity control, velocity feedback and spindle-at-speed signal. position control is there too, but have to test it yet. MDS-A-SVJ and MDS-B-SVJ2 do work. no absolute encoder/linear scales yet.
still couldn't get the only MDS-B-V1 drive i have a (limited) access to working. keep getting an AL36 after initialization. have to find a working setup to snoop at the protocol...
also implemented the SSCNET-I protocol. this should allow to control up to 8 (probably 15) MR-J2-B/MR-J2S-B drives in position/velocity mode. for now it uses a 3.55ms cycle, but i will try to get it down to 0.88ms later. at least for J2S drives...
8 years 6 months ago #108731 by wu-010@163.com
Anything I can help just tell me. The hardware is always cheaper in China than in Russia. MR-J3/MR-J4 is a huge progress.
8 years 6 months ago - 8 years 6 months ago #108744 by dm17ry
thanks! i've got everything i need for sscnet-iii for a while now. just have to find some spare time to take on it. hope to do it soon.
btw, how're your multi-axis machines? :)
i finally done multiple cards support...
root@hp:~# nyxq -0 servo info dev: /sys/bus/pci/devices/0000:05:04.0 MDS axes:7 enabled:4 online:4 spindle:0 2: [b3] pos= 4068 vel=0.0 trq=0.0 inp root@hp:~# nyxq -1 servo info dev: /sys/bus/pci/devices/0000:05:09.0 SSCNET-II axes:6 enabled:3f online:3f 0: [b0] pos= -15558074 vel=0.0 trq=0.0 inp zsp 1: [b1] pos= -7093935 vel=0.0 trq=0.0 inp zsp 2: [b2] pos= -72797 vel=0.0 trq=0.0 inp zsp 3: [16] pos= 0 vel=0.0 trq=0.0 inp zsp alm 4: [b4] pos= 1186675014 vel=0.0 trq=0.0 inp zsp 5: [b5] pos= 1682747213 vel=0.0 trq=0.0 inp zsp
Last edit: 8 years 6 months ago by dm17ry.
8 years 6 months ago #109797 by dm17ry
a bit of update for whom it may concern. implemented the spindle control, both velocity and position. position control may require some external HAL glue logic to switch gains in the amp, the pins to do it are present in the driver. so MDS-A-SVJ, MDS-B-SVJ2, MDS-A/B-SP should be functional. will begin more extensive testing next week.
and also i finally got the SSCNET-III interface card mostly working. need to finish the research on the protocol, try to fit everything still missing into 0.44ms (or better yet 0.22ms) cycle and implement required changes to the linuxcnc driver. few other things here and there and then all those J3/J4 amps off the ebay should be usable :)
The following user(s) said Thank You: wu-010@163.com
Time to create page: 0.064 seconds
