a couple of months turned into 4, but i finally got it spinning. here's the story...
got the MDS-A-SVJ-03 drive, bought a compatible motor on ebay. but the motor couldn't make it thru a mail from singapore for two months. got a refund. found another possibly compatible motor locally - HA-MH43. replaced encoder connector and luckily, the drive didn't complain. but when tried to spin it - it jerked and vibrated. i blamed misaligned encoder or wrong resolution. made a gadget to plug between the encoder and the amplifier intercepting the serial encoder protocol in attempt to understand what's going on. spent a week debugging. tried to modify encoder resolution on the fly - instant runaway and overload alarm. tried to shift encoder phase - no good either. then it came to me - maybe the drive is malfunctioning? looked inside, checked electrolytes - all fine. next, two HCPL-7806 current feedback isolation amplifiers. no datasheet, not available locally. desoldered, the silkscreen underneath says: HCPL-7800. great! plucked 7800 out of broken boards laying around, soldered in. and, finally, the damn thing works!
so, MDS-A-SVJ drives are working in incremental mode with 3.55ms servo cycle and up to 7 drives on the bus. most things in the protocol are clear like status bits, alarms, position/velocity/torque feedback, torque limit, special op mode. for now the firmware works with the same sscnet-ii linuxcnc driver. it needs more work to properly implement parameters setting (now they are just saved in flash on the controller) and monitoring. desperately trying to find some time to rewrite the driver and unify sscnet ii, MDS and upcoming sscnet i and iii. and, possibly, have a look at mechatrolink as well...
next thing is the MDS-A-SP spindle. will be a bit tricky - it doesn't report encoder position in velocity control mode. meldas control switch it to position control mode for rigid tapping... will report progress
