joel@konor ~> timer /usr/bin/linuxcnc '/home/joel/Build/linuxcnc/configs/sim.axis/axis.ini'
LINUXCNC - 2.7.11
Machine configuration directory is '/home/joel/Build/linuxcnc/configs/sim.axis'
Machine configuration file is 'axis.ini'
Starting LinuxCNC...
Found file(lib): /usr/share/linuxcnc/hallib/core_sim.hal
Note: Using POSIX realtime
Found file(lib): /usr/share/linuxcnc/hallib/sim_spindle_encoder.hal
Found file(lib): /usr/share/linuxcnc/hallib/axis_manualtoolchange.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
Found file(REL): ./check_constraints.hal
task: main loop took 0.010301 seconds
File "/usr/bin/axis", line 3141, in <module>
o = MyOpengl(widgets.preview_frame, width=400, height=300, double=1, depth=1)
File "/usr/bin/axis", line 353, in __init__
Opengl.__init__(self, *args, **kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 164, in __init__
apply(RawOpengl.__init__, (self, master, cnf), kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 112, in __init__
Togl.__init__(self, master, cnf, **kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 38, in __init__
Widget.__init__(self, master, 'togl', cnf, kw)
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 2099, in __init__
(widgetName, self._w) + extra + self._options(cnf))
_tkinter.TclError: NULL main window
task: 3721 cycles, min=0.000045, max=0.010301, avg=0.001195, 1 latency excursions (> 10x expected cycle time of 0.001000s)
LinuxCNC terminated with an error. You can find more information in the log:
/home/joel/linuxcnc_debug.txt
and
/home/joel/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Command exited with non-zero status 1
Ran for 0:09.97 min:sec
joel@konor ~>
[drm:r100_ring_test [radeon]] *ERROR* radeon: ring test failed (scratch(0x15E4)=0xCAFEDEAD)
[drm:r100_cp_init [radeon]] *ERROR* radeon: cp isn't working (-22).
radeon 0000:01:00.0: failed initializing CP (-22).
radeon 0000:01:00.0: Disabling GPU acceleration
[drm:r100_cp_fini [radeon]] *ERROR* Wait for CP idle timeout, shutting down CP.
vesa: Ignoring device with a bound kernel driver
(WW) Falling back to old probe method for vesa
(EE) Screen 0 deleted because of no matching config section.
(II) UnloadModule: "vesa"
(EE) Device(s) detected, but none match those in the config file.
(EE)
Fatal server error: (EE) no screens found(EE)
andypugh wrote: Can you try one of the low-graphics configs, see how that goes?
Maybe sim/touchy ? or sim/tklinuxcnc
