building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel
- dbanks
8 years 6 months ago #108695
by dbanks
Replied by dbanks on topic building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel
Comes up with 4.13.0-38 generic, which by my masterful googling seems to be no good.
- dbanks
8 years 6 months ago #108697
by dbanks
I got to Grub it was esc AFTER my bios screen. However selecting the kernel says unable to mount root fs on unknown block. Any ideas?!
- thang
- Thank you received: 11
8 years 6 months ago #108698
by thang
Replied by thang on topic building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel
did you try the link i give you above? Normally when i install newer realtime kernel, it will automatic select rt kernal. Try command to see which kernel did you install :
cd /boot
ls
cd /boot
ls
- dbanks
8 years 6 months ago #108709
by dbanks
I utilized the link you had. It error'd saying it failed to load when selected. The patch link was dead though, and I was unable to locate a fix for that. That could be part of it. Apologies in advance, obviously new at this stuff.
- thang
8 years 6 months ago - 8 years 6 months ago #108713
by thang
i edit link:
wget mirrors.edge.kernel.org/pub/linux/kernel...4.9.47-rt37.patch.gz
Last edit: 8 years 6 months ago by thang.
- thang
8 years 6 months ago #108714
by thang
i tried google and found this:
askubuntu.com/questions/41930/kernel-pan...-on-unknown-block0-0
not sure if it can fix your bug.
Time to create page: 0.212 seconds
