- Thank you received: 7491
building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel
3 years 10 months ago #260234
Replied by tommylight on topic building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel
Not sure about the first, seems like using "make" in the wrong folder
The second should be " make clean" not "make clear".
- akg1904
- Thank you received: 4
3 years 10 months ago #260236
by akg1904
Replied by akg1904 on topic building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel
Hi Tommylight,
Thank you for your reply.
I did "make clean" as you suggested and I got almost error free output as shown below:
/bin/sh: 1: Syntax error: "(" unexpected (expecting "then")
rm -rf \
pluto_servo_firmware/db \
pluto_servo_firmware/pluto_servo.asm.rpt \
pluto_servo_firmware/pluto_servo.done \
pluto_servo_firmware/pluto_servo.fit.rpt \
pluto_servo_firmware/pluto_servo.fit.summary \
pluto_servo_firmware/pluto_servo.flow.rpt \
pluto_servo_firmware/pluto_servo.map.rpt \
pluto_servo_firmware/pluto_servo.map.summary \
pluto_servo_firmware/pluto_servo.pin \
pluto_servo_firmware/pluto_servo.pof \
pluto_servo_firmware/pluto_servo.qws \
pluto_servo_firmware/pluto_servo.rbf \
pluto_servo_firmware/pluto_servo.sof \
pluto_servo_firmware/pluto_servo.tan.rpt \
pluto_servo_firmware/pluto_servo.tan.summary \
pluto_servo_firmware/undo_redo.txt
rm -f hal/user_comps/wj200_vfd/wj200_vfd.c
rm -f hal/user_comps/wj200_vfd/wj200_vfd.1
rm -f hal/user_comps/pi500_vfd/pi500_vfd.c
rm -f hal/user_comps/pi500_vfd/pi500_vfd.1
rm -f ../tests/halcompile/personalities_mod/lincurve_test.comp ../tests/halcompile/personalities_mod/logic_test.comp ../tests/halcompile/personalities_mod/bitslice_test.comp \
../tests/halcompile/serial-out-of-tree/mesa_uart_test.comp \
../tests/halcompile/userspace/rand_test.comp \
../tests/uspace/spawnv-root/rtapi.conf
rm -rf local hal-test.html ini-test.html ngc-test.html
rm -f ../bin/pyvcp ../bin/hal_input ../bin/gladevcp ../bin/scorbot-er-3 ../bin/mitsub_vfd ../bin/pmx485 ../bin/sim-torch ../bin/z_level_compensation ../bin/pumagui ../bin/puma560gui ../bin/lineardelta ../bin/scaragui ../bin/hexagui ../bin/5axisgui ../bin/max5gui ../bin/maho600gui ../bin/hbmgui ../bin/rotarydelta ../bin/melfagui ../bin/millturngui ../bin/xyzac-trt-gui ../bin/xyzbc-trt-gui ../lib/python/_hal.so ../lib/python/linuxcnc.so ../lib/python/_togl.so ../bin/axis ../bin/axis-remote ../bin/linuxcnctop ../bin/hal_manualtoolchange ../bin/mdi ../bin/image-to-gcode ../bin/lintini ../bin/debuglevel ../bin/teach-in ../bin/tracking-test ../bin/touchy ../lib/python/touchy/__init__.py ../lib/python/touchy/mdi.py ../lib/python/touchy/emc_interface.py ../lib/python/touchy/hal_interface.py ../lib/python/touchy/filechooser.py ../lib/python/touchy/listing.py ../lib/python/touchy/preferences.py ../share/linuxcnc/touchy.glade ../bin/stepconf ../lib/python/stepconf/__init__.py ../share/linuxcnc/linuxcnc-wizard.gif ../lib/python/stepconf/pages.py ../lib/python/stepconf/build_INI.py ../lib/python/stepconf/build_HAL.py ../lib/python/stepconf/import_mach.py ../share/linuxcnc/stepconf/main_page.glade ../share/linuxcnc/stepconf/base.glade ../share/linuxcnc/stepconf/start.glade ../share/linuxcnc/stepconf/pport1.glade ../share/linuxcnc/stepconf/pport2.glade ../share/linuxcnc/stepconf/spindle.glade ../share/linuxcnc/stepconf/options.glade ../share/linuxcnc/stepconf/halui_page.glade ../share/linuxcnc/stepconf/ubuttons.glade ../share/linuxcnc/stepconf/thcad.glade ../share/linuxcnc/stepconf/axisx.glade ../share/linuxcnc/stepconf/axisy.glade ../share/linuxcnc/stepconf/axisz.glade ../share/linuxcnc/stepconf/axisu.glade ../share/linuxcnc/stepconf/axisv.glade ../share/linuxcnc/stepconf/axisa.glade ../share/linuxcnc/stepconf/finished.glade ../bin/pncconf ../lib/python/pncconf/__init__.py ../lib/python/pncconf/pages.py ../lib/python/pncconf/build_INI.py ../lib/python/pncconf/build_HAL.py ../lib/python/pncconf/private_data.py ../lib/python/pncconf/tests.py ../lib/python/pncconf/data.py ../share/linuxcnc/pncconf/main_page.glade ../share/linuxcnc/pncconf/help.glade ../share/linuxcnc/pncconf/mesa0.glade ../share/linuxcnc/pncconf/mesa1.glade ../share/linuxcnc/pncconf/start.glade ../share/linuxcnc/pncconf/external.glade ../share/linuxcnc/pncconf/base.glade ../share/linuxcnc/pncconf/screen.glade ../share/linuxcnc/pncconf/vcp.glade ../share/linuxcnc/pncconf/ubuttons.glade ../share/linuxcnc/pncconf/thcad.glade ../share/linuxcnc/pncconf/x_axis.glade ../share/linuxcnc/pncconf/x_motor.glade ../share/linuxcnc/pncconf/y_axis.glade ../share/linuxcnc/pncconf/y_motor.glade ../share/linuxcnc/pncconf/z_axis.glade ../share/linuxcnc/pncconf/z_motor.glade ../share/linuxcnc/pncconf/a_axis.glade ../share/linuxcnc/pncconf/a_motor.glade ../share/linuxcnc/pncconf/s_motor.glade ../share/linuxcnc/pncconf/options.glade ../share/linuxcnc/pncconf/realtime.glade ../share/linuxcnc/pncconf/pport1.glade ../share/linuxcnc/pncconf/pport2.glade ../share/linuxcnc/pncconf/dialogs.glade ../share/linuxcnc/pncconf/finished.glade ../bin/gremlin ../lib/python/gremlin.py ../lib/python/qt5_graphics.py ../bin/gscreen ../lib/python/gscreen/__init__.py ../lib/python/gscreen/mdi.py ../lib/python/gscreen/emc_interface.py ../lib/python/gscreen/preferences.py ../lib/python/gscreen/keybindings.py ../share/linuxcnc/gscreen.glade ../share/linuxcnc/gscreen2.glade ../bin/pyui ../lib/python/pyui/master.py ../lib/python/pyui/widgets.py ../lib/python/pyui/__init__.py ../lib/python/pyui/commands.py ../lib/python/pyui/panelui_validate.py ../lib/python/pyui/panelui_spec.ini ../lib/python/pyui/_panelui.ini ../bin/qtvcp ../bin/gmoccapy ../lib/python/gmoccapy/__init__.py ../lib/python/gmoccapy/dialogs.py ../lib/python/gmoccapy/getiniinfo.py ../lib/python/gmoccapy/notification.py ../lib/python/gmoccapy/player.py ../lib/python/gmoccapy/preferences.py ../lib/python/gmoccapy/widgets.py ../lib/python/gmoccapy/icon_theme_helper.py ../share/gmoccapy/gmoccapy.glade ../bin/qtplasmac-materials ../bin/qtplasmac-plasmac2qt ../bin/qtplasmac-cfg2prefs ../bin/qtplasmac_gcode ../bin/pmx485-test ../configs/by_machine/qtplasmac/M190 ../bin/mdro ../lib/python/lineardeltakins.so ../lib/python/rotarydeltakins.so ../bin/update_ini ../lib/python/gcode.so
find ../lib/python -name '*.so' -exec rm {} +
find . -name __pycache__ | xargs -r rm -r
bash -c 'for f in `find ./ -name "cscope.*out"`;do rm $f;done'
rm -f ../include/linuxcnc.h ../include/emcIniFile.hh ../include/iniaxis.hh ../include/inijoint.hh ../include/inispindle.hh ../include/initraj.hh ../include/inihal.hh ../include/cubic.h ../include/kinematics.h ../include/switchkins.h ../include/genhexkins.h ../include/genserkins.h ../include/pentakins.h ../include/pumakins.h ../include/tc.h ../include/tc_types.h ../include/tcq.h ../include/tp.h ../include/tp_types.h ../include/spherical_arc.h ../include/blendmath.h ../include/emcmotcfg.h ../include/motion.h ../include/homing.h ../include/simple_tp.h ../include/state_tag.h ../include/usrmotintf.h ../include/canon.hh ../include/canon_position.hh ../include/emctool.h ../include/emc.hh ../include/emc_nml.hh ../include/emccfg.h ../include/emcglb.h ../include/emcpos.h ../include/emcpose.h ../include/interp_return.hh ../include/interpl.hh ../include/motion_types.h ../include/debugflags.h ../include/interp_internal.hh ../include/interp_fwd.hh ../include/interp_base.hh ../include/modal_state.hh ../include/rs274ngc.hh ../include/saicanon.hh ../include/hal.h ../include/hal_parport.h ../include/hostmot2-serial.h ../include/nyx3.h ../include/locmem.hh ../include/memsem.hh ../include/phantom.hh ../include/physmem.hh ../include/recvn.h ../include/rem_msg.hh ../include/sendn.h ../include/shmem.hh ../include/tcpmem.hh ../include/cms.hh ../include/cms_aup.hh ../include/cms_cfg.hh ../include/cms_dup.hh ../include/cms_srv.hh ../include/cms_up.hh ../include/cms_user.hh ../include/cms_xup.hh ../include/cmsdiag.hh ../include/tcp_opts.hh ../include/tcp_srv.hh ../include/inifile.h ../include/inifile.hh ../include/linklist.hh ../include/cmd_msg.hh ../include/nml.hh ../include/nml_mod.hh ../include/nml_oi.hh ../include/nml_srv.hh ../include/nml_type.hh ../include/nmldiag.hh ../include/nmlmsg.hh ../include/stat_msg.hh ../include/_sem.h ../include/sem.hh ../include/_shm.h ../include/shm.hh ../include/_timer.h ../include/timer.hh ../include/posemath.h ../include/gotypes.h ../include/gomath.h ../include/sincos.h ../include/rcs.hh ../include/rcs_exit.hh ../include/rcs_print.hh ../include/rcsversion.h ../include/rtapi.h ../include/rtapi_app.h ../include/rtapi_atomic.h ../include/rtapi_bitops.h ../include/rtapi_bool.h ../include/rtapi_byteorder.h ../include/rtapi_device.h ../include/rtapi_firmware.h ../include/rtapi_gfp.h ../include/rtapi_io.h ../include/rtapi_limits.h ../include/rtapi_list.h ../include/rtapi_math.h ../include/rtapi_math_i386.h ../include/rtapi_math64.h ../include/rtapi_mutex.h ../include/rtapi_parport.h ../include/rtapi_pci.h ../include/rtapi_slab.h ../include/rtapi_stdint.h ../include/rtapi_ctype.h ../include/rtapi_errno.h ../include/rtapi_string.h ../include/rtapi_vsnprintf.h
find . -name '*.o' |xargs rm -f
rm -rf objects
rm -f ../lib/liblinuxcncini.so ../lib/liblinuxcncini.so.0 ../bin/inivar ../lib/libposemath.so ../lib/libposemath.so.0 ../lib/libnml.so ../lib/libnml.so.0 ../bin/rtapi_app manpages ../bin/halstreamer ../bin/halsampler ../bin/panelui ../bin/mb2hal ../bin/gs2_vfd ../bin/hy_gt_vfd ../bin/svd-ps_vfd ../bin/shuttle ../bin/xhc-hb04 ../bin/sendkeys ../bin/thermistor ../bin/vfs11_vfd ../bin/classicladder ../tcl/hal.so ../bin/halcmd ../bin/halrmt ../bin/halmeter ../bin/halscope ../bin/halcompile ../bin/elbpcom ../bin/nyxflash ../bin/nyxq ../bin/zmapload ../bin/probe2stl ../bin/stlvis ../bin/zmapview ../lib/liblinuxcnchal.so ../lib/liblinuxcnchal.so.0 ../bin/vfdb_vfd ../bin/wj200_vfd ../bin/pi500_vfd ../bin/hy_vfd ../bin/xhc-whb04b-6 ../tcl/linuxcnc.so ../bin/linuxcncrsh ../bin/schedrmt ../bin/linuxcnclcd ../bin/halui ../lib/liblinuxcnc.a ../bin/linuxcncsvr ../bin/milltask ../bin/io ../bin/iov2 ../bin/genserkins ../lib/libcanterp.so ../lib/libcanterp.so.0 ../lib/librs274.so ../lib/librs274.so.0 ../bin/rs274 ../lib/libpyplugin.so.0 ../bin/motion-logger ../bin/tool_mmap_read ../lib/libtooldata.so ../lib/libtooldata.so.0 ../bin/tool_watch ../bin/linuxcnc_module_helper ../share/locale/cs/LC_MESSAGES/linuxcnc.mo ../share/locale/da/LC_MESSAGES/linuxcnc.mo ../share/locale/de/LC_MESSAGES/linuxcnc.mo ../share/locale/es/LC_MESSAGES/linuxcnc.mo ../share/locale/fi/LC_MESSAGES/linuxcnc.mo ../share/locale/fr/LC_MESSAGES/linuxcnc.mo ../share/locale/hu/LC_MESSAGES/linuxcnc.mo ../share/locale/it/LC_MESSAGES/linuxcnc.mo ../share/locale/ja/LC_MESSAGES/linuxcnc.mo ../share/locale/nb/LC_MESSAGES/linuxcnc.mo ../share/locale/pl/LC_MESSAGES/linuxcnc.mo ../share/locale/pt_BR/LC_MESSAGES/linuxcnc.mo ../share/locale/ro/LC_MESSAGES/linuxcnc.mo ../share/locale/ru/LC_MESSAGES/linuxcnc.mo ../share/locale/sk/LC_MESSAGES/linuxcnc.mo ../share/locale/sr/LC_MESSAGES/linuxcnc.mo ../share/locale/sv/LC_MESSAGES/linuxcnc.mo ../share/locale/vi/LC_MESSAGES/linuxcnc.mo ../share/locale/zh_CN/LC_MESSAGES/linuxcnc.mo ../share/locale/zh_HK/LC_MESSAGES/linuxcnc.mo ../share/locale/zh_TW/LC_MESSAGES/linuxcnc.mo ../share/locale/cs/LC_MESSAGES/gmoccapy.mo ../share/locale/da/LC_MESSAGES/gmoccapy.mo ../share/locale/de/LC_MESSAGES/gmoccapy.mo ../share/locale/es/LC_MESSAGES/gmoccapy.mo ../share/locale/fr/LC_MESSAGES/gmoccapy.mo ../share/locale/hu/LC_MESSAGES/gmoccapy.mo ../share/locale/it/LC_MESSAGES/gmoccapy.mo ../share/locale/nb/LC_MESSAGES/gmoccapy.mo ../share/locale/pl/LC_MESSAGES/gmoccapy.mo ../share/locale/sk/LC_MESSAGES/gmoccapy.mo ../share/locale/sr/LC_MESSAGES/gmoccapy.mo ../share/locale/vi/LC_MESSAGES/gmoccapy.mo ../share/locale/zh_CN/LC_MESSAGES/gmoccapy.mo manpages headers ../share/locale/cs/LC_MESSAGES/linuxcnc.mo ../share/locale/da/LC_MESSAGES/linuxcnc.mo ../share/locale/de/LC_MESSAGES/linuxcnc.mo ../share/locale/es/LC_MESSAGES/linuxcnc.mo ../share/locale/fi/LC_MESSAGES/linuxcnc.mo ../share/locale/fr/LC_MESSAGES/linuxcnc.mo ../share/locale/hu/LC_MESSAGES/linuxcnc.mo ../share/locale/it/LC_MESSAGES/linuxcnc.mo ../share/locale/ja/LC_MESSAGES/linuxcnc.mo ../share/locale/nb/LC_MESSAGES/linuxcnc.mo ../share/locale/pl/LC_MESSAGES/linuxcnc.mo ../share/locale/pt_BR/LC_MESSAGES/linuxcnc.mo ../share/locale/ro/LC_MESSAGES/linuxcnc.mo ../share/locale/ru/LC_MESSAGES/linuxcnc.mo ../share/locale/sk/LC_MESSAGES/linuxcnc.mo ../share/locale/sr/LC_MESSAGES/linuxcnc.mo ../share/locale/sv/LC_MESSAGES/linuxcnc.mo ../share/locale/vi/LC_MESSAGES/linuxcnc.mo ../share/locale/zh_CN/LC_MESSAGES/linuxcnc.mo ../share/locale/zh_HK/LC_MESSAGES/linuxcnc.mo ../share/locale/zh_TW/LC_MESSAGES/linuxcnc.mo ../share/locale/cs/LC_MESSAGES/gmoccapy.mo ../share/locale/da/LC_MESSAGES/gmoccapy.mo ../share/locale/de/LC_MESSAGES/gmoccapy.mo ../share/locale/es/LC_MESSAGES/gmoccapy.mo ../share/locale/fr/LC_MESSAGES/gmoccapy.mo ../share/locale/hu/LC_MESSAGES/gmoccapy.mo ../share/locale/it/LC_MESSAGES/gmoccapy.mo ../share/locale/nb/LC_MESSAGES/gmoccapy.mo ../share/locale/pl/LC_MESSAGES/gmoccapy.mo ../share/locale/sk/LC_MESSAGES/gmoccapy.mo ../share/locale/sr/LC_MESSAGES/gmoccapy.mo ../share/locale/vi/LC_MESSAGES/gmoccapy.mo ../share/locale/zh_CN/LC_MESSAGES/gmoccapy.mo objects/cs.msg objects/da.msg objects/de.msg objects/es.msg objects/fi.msg objects/fr.msg objects/hu.msg objects/it.msg objects/ja.msg objects/nb.msg objects/pl.msg objects/pt_BR.msg objects/ro.msg objects/ru.msg objects/sk.msg objects/sr.msg objects/sv.msg objects/vi.msg objects/zh_CN.msg objects/zh_HK.msg objects/zh_TW.msg ../bin/tooledit ../bin/ngcgui ../bin/pyngcgui ../bin/gremlin_view ../bin/halshow
rm -f ../docs/man/man9/abs.9 ../docs/man/man9/abs_s32.9 ../docs/man/man9/and2.9 ../docs/man/man9/anglejog.9 ../docs/man/man9/axistest.9 ../docs/man/man9/bin2gray.9 ../docs/man/man9/biquad.9 ../docs/man/man9/bitslice.9 ../docs/man/man9/bitwise.9 ../docs/man/man9/bldc.9 ../docs/man/man9/blend.9 ../docs/man/man9/carousel.9 ../docs/man/man9/charge_pump.9 ../docs/man/man9/clarke2.9 ../docs/man/man9/clarke3.9 ../docs/man/man9/clarkeinv.9 ../docs/man/man9/comp.9 ../docs/man/man9/constant.9 ../docs/man/man9/conv_bit_float.9 ../docs/man/man9/conv_bit_s32.9 ../docs/man/man9/conv_bit_u32.9 ../docs/man/man9/conv_float_s32.9 ../docs/man/man9/conv_float_u32.9 ../docs/man/man9/conv_s32_bit.9 ../docs/man/man9/conv_s32_float.9 ../docs/man/man9/conv_s32_u32.9 ../docs/man/man9/conv_u32_bit.9 ../docs/man/man9/conv_u32_float.9 ../docs/man/man9/conv_u32_s32.9 ../docs/man/man9/corexy_by_hal.9 ../docs/man/man9/dbounce.9 ../docs/man/man9/ddt.9 ../docs/man/man9/deadzone.9 ../docs/man/man9/demux.9 ../docs/man/man9/differential.9 ../docs/man/man9/div2.9 ../docs/man/man9/edge.9 ../docs/man/man9/eoffset_per_angle.9 ../docs/man/man9/estop_latch.9 ../docs/man/man9/fagor.9 ../docs/man/man9/feedcomp.9 ../docs/man/man9/filter_kalman.9 ../docs/man/man9/flipflop.9 ../docs/man/man9/gantry.9 ../docs/man/man9/gearchange.9 ../docs/man/man9/gray2bin.9 ../docs/man/man9/histobins.9 ../docs/man/man9/homecomp.9 ../docs/man/man9/hypot.9 ../docs/man/man9/ilowpass.9 ../docs/man/man9/integ.9 ../docs/man/man9/invert.9 ../docs/man/man9/jogpad.9 ../docs/man/man9/joyhandle.9 ../docs/man/man9/knob2float.9 ../docs/man/man9/laserpower.9 ../docs/man/man9/latencybins.9 ../docs/man/man9/limit1.9 ../docs/man/man9/limit2.9 ../docs/man/man9/limit3.9 ../docs/man/man9/lincurve.9 ../docs/man/man9/logic.9 ../docs/man/man9/lowpass.9 ../docs/man/man9/lut5.9 ../docs/man/man9/magazine.9 ../docs/man/man9/maj3.9 ../docs/man/man9/match8.9 ../docs/man/man9/matrixkins.9 ../docs/man/man9/max31855.9 ../docs/man/man9/mdssp.9 ../docs/man/man9/mesa_pktgyro_test.9 ../docs/man/man9/message.9 ../docs/man/man9/millturn.9 ../docs/man/man9/minmax.9 ../docs/man/man9/moveoff.9 ../docs/man/man9/mult2.9 ../docs/man/man9/multiclick.9 ../docs/man/man9/multiswitch.9 ../docs/man/man9/mux16.9 ../docs/man/man9/mux2.9 ../docs/man/man9/mux4.9 ../docs/man/man9/mux8.9 ../docs/man/man9/near.9 ../docs/man/man9/nist.9 ../docs/man/man9/not.9 ../docs/man/man9/offset.9 ../docs/man/man9/ohmic.9 ../docs/man/man9/oneshot.9 ../docs/man/man9/or2.9 ../docs/man/man9/orient.9 ../docs/man/man9/passthru.9 ../docs/man/man9/plasmac.9 ../docs/man/man9/plotoffsets.9 ../docs/man/man9/probemux.9 ../docs/man/man9/raster.9 ../docs/man/man9/reset.9 ../docs/man/man9/sample_hold.9 ../docs/man/man9/scale.9 ../docs/man/man9/scaled_s32_sums.9 ../docs/man/man9/select8.9 ../docs/man/man9/sim_axis_hardware.9 ../docs/man/man9/sim_home_switch.9 ../docs/man/man9/sim_matrix_kb.9 ../docs/man/man9/sim_parport.9 ../docs/man/man9/sim_spindle.9 ../docs/man/man9/simple_tp.9 ../docs/man/man9/sphereprobe.9 ../docs/man/man9/spindle.9 ../docs/man/man9/spindle_monitor.9 ../docs/man/man9/steptest.9 ../docs/man/man9/sum2.9 ../docs/man/man9/tangent.9 ../docs/man/man9/thc.9 ../docs/man/man9/thcud.9 ../docs/man/man9/threadtest.9 ../docs/man/man9/time.9 ../docs/man/man9/timedelay.9 ../docs/man/man9/timedelta.9 ../docs/man/man9/tof.9 ../docs/man/man9/toggle.9 ../docs/man/man9/toggle2.9 ../docs/man/man9/toggle2nist.9 ../docs/man/man9/ton.9 ../docs/man/man9/tp.9 ../docs/man/man9/tristate_bit.9 ../docs/man/man9/tristate_float.9 ../docs/man/man9/updown.9 ../docs/man/man9/userkins.9 ../docs/man/man9/wcomp.9 ../docs/man/man9/xhc_hb04_util.9 ../docs/man/man9/xor2.9 ../docs/man/man9/yop.9 ../docs/man/man9/tpcomp.9 ../docs/man/man9/serport.9 ../docs/man/man9/mesa_7i65.9 ../docs/man/man9/mesa_uart.9 ../docs/man/man9/nyx.9 ../docs/man/man1/thermistor.1 ../docs/man/man1/wj200_vfd.1 ../docs/man/man1/pi500_vfd.1 ../docs/man/man1/linuxcnc.1 ../docs/man/man1/halstreamer.1 ../docs/man/man1/hy_gt_vfd.1 ../docs/man/man1/sendkeys.1 ../docs/man/man1/svd-ps_vfd.1 ../docs/man/man1/xhc-whb04b-6.1 ../docs/man/man9/streamer.9 ../docs/man/man1/halstreamer.1 ../docs/man/man1/hy_gt_vfd.1 ../docs/man/man1/sendkeys.1 ../docs/man/man1/svd-ps_vfd.1 ../docs/man/man1/xhc-whb04b-6.1 ../docs/man/man9/streamer.9
rm -f ../rtlib/*..so
rm -f hal/components/conv_*.comp
rm -rf depends
find -name '.*.cmd' -or -name '*.ko' -or -name '*.mod.c' -or -name '*.mod.o' | xargs rm -f
rm -rf .tmp_versions
find . -name .tmp_versions |xargs rm -rf
rm -f ../rtlib/*.ko
rm -f ../rtlib/*.so
as you can see I got syntax error in first line
After that I did "sudo make -j4" and I am getting following errors:
Reading 0/207 dependency files
Done reading dependencies
Reading 0/114 realtime dependency files
Done reading realtime dependencies
Creating mesa_uart.mak
Creating mesa_7i65.mak
Creating serport.mak
Creating yop.mak
Creating xor2.mak
Creating xhc_hb04_util.mak
Creating wcomp.mak
Creating userkins.mak
Creating updown.mak
Creating tristate_float.mak
Creating tristate_bit.mak
Creating ton.mak
Creating toggle2nist.mak
Creating tp.mak
Creating toggle2.mak
Creating toggle.mak
Creating tof.mak
Creating timedelta.mak
Creating timedelay.mak
Creating time.mak
Creating threadtest.mak
Creating thcud.mak
Creating thc.mak
Creating tangent.mak
Creating sum2.mak
Creating steptest.mak
Creating spindle_monitor.mak
Creating spindle.mak
Creating sphereprobe.mak
Creating simple_tp.mak
Creating sim_spindle.mak
Creating sim_parport.mak
Creating sim_matrix_kb.mak
Creating sim_home_switch.mak
Creating sim_axis_hardware.mak
Creating select8.mak
Creating scaled_s32_sums.mak
Creating scale.mak
Creating sample_hold.mak
Creating reset.mak
Creating raster.mak
Creating probemux.mak
Creating plotoffsets.mak
Creating plasmac.mak
Creating passthru.mak
Creating orient.mak
Creating or2.mak
Creating oneshot.mak
Creating ohmic.mak
Creating offset.mak
Creating not.mak
Creating nist.mak
Creating near.mak
Creating mux8.mak
Creating mux4.mak
Creating mux2.mak
Creating mux16.mak
Creating multiswitch.mak
Creating multiclick.mak
Creating mult2.mak
Creating moveoff.mak
Creating minmax.mak
Creating millturn.mak
Creating message.mak
Creating mesa_pktgyro_test.mak
Creating mdssp.mak
Creating max31855.mak
Creating matrixkins.mak
Creating match8.mak
Creating maj3.mak
Creating magazine.mak
Creating lut5.mak
Creating lowpass.mak
Creating logic.mak
Creating lincurve.mak
Creating limit3.mak
Creating limit2.mak
Creating limit1.mak
Creating latencybins.mak
Creating laserpower.mak
Creating knob2float.mak
Creating joyhandle.mak
Creating jogpad.mak
Creating invert.mak
Creating integ.mak
Creating ilowpass.mak
Creating hypot.mak
Creating homecomp.mak
Creating histobins.mak
Creating gray2bin.mak
Creating gearchange.mak
Creating gantry.mak
Creating flipflop.mak
Creating filter_kalman.mak
Creating feedcomp.mak
Creating fagor.mak
Creating estop_latch.mak
Creating eoffset_per_angle.mak
Creating edge.mak
Creating div2.mak
Creating differential.mak
Creating demux.mak
Creating deadzone.mak
Creating ddt.mak
Creating dbounce.mak
Creating corexy_by_hal.mak
converting conv for conv_u32_s32.comp
converting conv for conv_u32_float.comp
converting conv for conv_u32_bit.comp
converting conv for conv_s32_u32.comp
converting conv for conv_s32_float.comp
converting conv for conv_s32_bit.comp
converting conv for conv_float_u32.comp
converting conv for conv_float_s32.comp
converting conv for conv_bit_u32.comp
converting conv for conv_bit_s32.comp
converting conv for conv_bit_float.comp
Creating constant.mak
Creating comp.mak
Creating clarkeinv.mak
Creating clarke3.mak
Creating clarke2.mak
Creating charge_pump.mak
Creating carousel.mak
Creating blend.mak
Creating bldc.mak
Creating bitwise.mak
Creating bitslice.mak
Creating biquad.mak
Creating bin2gray.mak
Creating axistest.mak
Creating anglejog.mak
Creating and2.mak
Creating abs_s32.mak
Creating abs.mak
Creating conv_u32_s32.mak
Creating conv_u32_float.mak
Creating conv_u32_bit.mak
Creating conv_s32_u32.mak
Creating conv_s32_float.mak
Creating conv_s32_bit.mak
Creating conv_float_u32.mak
Creating conv_float_s32.mak
Creating conv_bit_u32.mak
Creating conv_bit_s32.mak
Creating conv_bit_float.mak
Reading 0/250 realtime dependency files
Copying test input hal/components/lincurve.comp
Copying test input hal/components/logic.comp
Copying test input hal/components/bitslice.comp
sed hal/drivers/mesa_uart.comp -e "1 s/mesa_uart/mesa_uart_test/" > ../tests/halcompile/serial-out-of-tree/mesa_uart_test.comp
sed ../docs/src/hal/rand.comp -e "1 s/rand/rand_test/" > ../tests/halcompile/userspace/rand_test.comp
cp ../scripts/rtapi.conf ../tests/uspace/spawnv-root/rtapi.conf
Compiling libnml/inifile/inifile.cc
Compiling libnml/inifile/inivar.cc
Compiling libnml/posemath/_posemath.c
Compiling libnml/posemath/posemath.cc
make: *** [Makefile:286: objects/libnml/inifile/inifile.o] Error 2
make: *** Waiting for unfinished jobs....
make: *** [Makefile:285: objects/libnml/inifile/inivar.o] Error 2
make: *** [Makefile:278: objects/libnml/posemath/_posemath.o] Error 2
make: *** [Makefile:286: objects/libnml/posemath/posemath.o] Error 2
I don't know why it is still giving the error
Regards
Abhishek
rm -rf \
rm -rf objects
rm -rf depends
rm -f ../rtlib/*.ko
rm -f ../rtlib/*.so
Creating yop.mak
Creating xor2.mak
Creating wcomp.mak
Creating updown.mak
Creating ton.mak
Creating tp.mak
Creating toggle.mak
Creating tof.mak
Creating time.mak
Creating thcud.mak
Creating thc.mak
Creating sum2.mak
Creating scale.mak
Creating reset.mak
Creating raster.mak
Creating orient.mak
Creating or2.mak
Creating ohmic.mak
Creating offset.mak
Creating not.mak
Creating nist.mak
Creating near.mak
Creating mux8.mak
Creating mux4.mak
Creating mux2.mak
Creating mux16.mak
Creating mult2.mak
Creating minmax.mak
Creating mdssp.mak
Creating match8.mak
Creating maj3.mak
Creating lut5.mak
Creating logic.mak
Creating limit3.mak
Creating limit2.mak
Creating limit1.mak
Creating jogpad.mak
Creating invert.mak
Creating integ.mak
Creating hypot.mak
Creating gantry.mak
Creating fagor.mak
Creating edge.mak
Creating div2.mak
Creating demux.mak
Creating ddt.mak
Creating comp.mak
Creating blend.mak
Creating bldc.mak
Creating biquad.mak
Creating and2.mak
Creating abs.mak
Regards
Abhishek
3 years 10 months ago #260237
Are you aware that there are ready made debs for Ubuntu 16?
Also, why are you using Ubuntu 16???
If you are trying to build LinuxCNC 2.9 or Master 2.10, there are to many changes in Python, so probably will not work.
If you are not making changes to source code, using new Ubuntu or Mint or Debian is easy to install LinuxCNC as it is in the testing repos of Debian, so give this a try, it is for Mint but should also work on new Ubuntu:
forum.linuxcnc.org/9-installing-linuxcnc...ter-on-linux-mint-21
The following user(s) said Thank You: akg1904
- akg1904
3 years 10 months ago #260276
by akg1904
I am using Debian 11 and is trying to build Linuxcnc 2.10 and was following the guide but during "make" it some how keep giving some error..
Regards
Abhishek
Regards
Abhishek
3 years 10 months ago #260277
3 years 10 months ago #260289
If feels like possibly you have a corrupted file. Try a complete reset:
Replied by andypugh on topic building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel
You seem to be having that a lot. Which is odd.
git reset --hard origin/master
git clean
make clean
./autogen.sh
./configure --with-realtime=uspace
make
sudo make setuid
Time to create page: 0.704 seconds
