- Thank you received: 4153
building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel
8 years 6 months ago #109315
Replied by rodw on topic building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel
Grotius, When you type uname -a do you see PREEMPT-RT?
Thats where I think the problem is. Somehow you've got the build environment making a .deb for RTAI not PREEMPT-RT so its looking for a dependency that does not exist for your kernel.
- Grotius
- Thank you received: 2349
8 years 6 months ago - 8 years 6 months ago #109316
by Grotius
Replied by Grotius on topic building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel
Hi Rodw,
Yes i always see the rt kernel.
Yes you are right. It had to do with a configuration that was not compatible. With the use of uspace everything is compatible.
I solved the problem just second's ago, from this document : linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
> git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev
> cd linuxcnc-dev/debian
> ./configure uspace
> cd ..
> dpkg-buildpackage -b -uc
No complaining about rt kernels....
It has to do with this tekst : uspace
Uspace : Configure the Debian package for Preempt-RT realtime or for non-realtime (these two are compatible).
My feeling is that i can try to make every possible combination now with everything working.
At least, that is what i think at the moment. :lol:
> ./configure uspace
> cd ..
Last edit: 8 years 6 months ago by Grotius.
8 years 6 months ago #109318
Glad I could help!
- jin_Technoaccord
5 years 3 months ago #216227
by jin_Technoaccord
Replied by jin_Technoaccord on topic building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel
Im running kernel version 4.15.0 on my desktop, but I cant find a patch of my version from the list. Can I use 4.16 or 4.14 instead?
Following is the link to the preempt set up page.
wiki.linuxfoundation.org/realtime/docume...ions/preemptrt_setup
5 years 3 months ago #216573
Just do step 4 here: linuxcnc.org/docs/2.8/html/getting-start...th_preempt_rt_kernel
Replied by andypugh on topic building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel
Just don't. If you want preempt-rt then just get the latest kernel in the package manager with the same major version number. Any 4.N.N kernel will work.Im running kernel version 4.15.0 on my desktop, but I cant find a patch of my version from the list. Can I use 4.16 or 4.14 instead?
- akg1904
3 years 10 months ago - 3 years 10 months ago #260230
by akg1904
Replied by akg1904 on topic building linuxcnc-dev on ubuntu 16.04 preempt-rt kernel
I was following the guide but I am facing errors when I try to build LinuxCNC.
The step at which I see an error is when I give the 'make -j4' command.
Below is the error I am getting.
Reading 0/207 dependency files
Done reading dependencies
/bin/sh: 1: Syntax error: "(" unexpected (expecting "then")
Reading 0/250 realtime dependency files
Done reading realtime dependencies
Compiling libnml/inifile/inifile.cc
Compiling libnml/inifile/inivar.cc
Compiling libnml/posemath/_posemath.c
Compiling libnml/posemath/posemath.cc
make: *** [Makefile:286: objects/libnml/inifile/inifile.o] Error 2
make: *** Waiting for unfinished jobs....
make: *** [Makefile:285: objects/libnml/inifile/inivar.o] Error 2
make: *** [Makefile:278: objects/libnml/posemath/_posemath.o] Error 2
make: *** [Makefile:286: objects/libnml/posemath/posemath.o] Error 2
Even at the 'make clear' step I get an error
make: *** No rule to make target 'clear'. Stop.
Anyone know what the problem might be?
Last edit: 3 years 10 months ago by akg1904.
Time to create page: 0.261 seconds
