Updating to latest version of 2.8
- Project_Hopeless
- Thank you received: 10
08 Jun 2019 00:53 #136263
by Project_Hopeless
Replied by Project_Hopeless on topic Updating to latest version of 2.8
Ok using Synaptic I some how upgraded to v2.9 !!!
Should I and how do I roll back to 2.8?
- Thank you received: 1480
08 Jun 2019 01:44 #136273
Replied by Todd Zuercher on topic Updating to latest version of 2.8
With the releasing of 2.8, Master, has progressed to 2.9-pre. Check your repos it is for Master, not 2.8. If you change your repos to reference the new 2.8 you, should be able to then use Synaptic to force versions back to 2.8.
- Thank you received: 4151
08 Jun 2019 09:26 #136289
Replied by rodw on topic Updating to latest version of 2.8
I would not be too concerned. Just run with V2.9.
Whats happened is that V2.8 development is frozen and its has been hived off in preparation for it to become the release version instead of V 2.7. The devs can no do final testing and bug fixes and build all the extra stuff for the website and the like pending the release.
- pl7i92
- Thank you received: 358
08 Jun 2019 12:56 #136291
by pl7i92
Replied by pl7i92 on topic Updating to latest version of 2.8
you may get a look here
gnipsel.com/linuxcnc/uspace/index.html
- Project_Hopeless
09 Jun 2019 16:46 #136387
by Project_Hopeless
Still loaded 2.9 pre. though No problem I'll run with it for now,
Yes that was much better, a fresh install. After all the messing around I've done I'm sure other things got jacked.you may get a look here
- BigJohnT
- Thank you received: 994
09 Jun 2019 17:30 #136392
by BigJohnT
Replied by BigJohnT on topic Updating to latest version of 2.8
Now you have reverse run!
If you build and install LinuxCNC using my instructions you just need to checkout the version you want before building... I need to update my instructions.
JT
JT
- mac44mag
10 Jun 2019 23:52 #136519
by mac44mag
Replied by mac44mag on topic Updating to latest version of 2.8
So, any time estimate on v2.8 going live? I'm in the process of setting up a CNC router and trying to decide whether or not to wait for 2.8.
Thanks!
Leonard
Thanks!
Leonard
11 Jun 2019 00:50 #136523
I would guess 1-3 weeks. If you plan to use 2.8 though, I would not bother with a 2.7 install. The differences in the config are significant. However I don't think you have to force yourself to wait for the official announcement, you can install it now from buildbot.
- mac44mag
11 Jun 2019 12:48 - 11 Jun 2019 12:53 #136595
by mac44mag
Thanks for the reply, Todd! If the release date is that close and the Beta's been locked down, the buildbot is the way to go. I'll do that.
I'll be using a Mesa 5i25 into a Gecko G540. Is the Preempt-RT kernel included in the Stretch Master branch distro? I'm sure that I'll have other questions as well..
Thank you, again, for the help!
Leonard
Leonard
Last edit: 11 Jun 2019 12:53 by mac44mag. Reason: Expanded question
11 Jun 2019 13:01 #136597
Yes, the Stretch iso comes with Preemt-RT. But you will have to change the repository to point to 2.8.
Time to create page: 0.246 seconds
