mac44mag wrote: As per your advice, threw out the old .ini/.hal and ran PCNconf. XYYZ config. New files attached.
I'm able to manually jog X and Y, but only with a single Y connected as one of the Y axis needs to be reversed. No output/movement on Z, but it works in axis. So:
1. I need to reverse joint travel on a stepper motor. I know that I need to set a "-1", but I'm not sure of the parameter.
2. Need to find out why 'Z' is dead.
Any suggestions/help would be appreciated. At least I'm communicating with the router! Yea!
Leonard
