(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
- Clive S
- Thank you received: 486
27 Aug 2020 06:38 #179662
by Clive S
I still use it and A friend of mine does. But if we are the only ones then we could switch
Replied by Clive S on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
So is anyone actually downloading and using the 19.2 ISO, if not I'll let the Domain & Server run down. No point paying for a server and DNS if the only use it gets is uploading linuxcnc packages that no one uses.
- BeagleBrainz
- Visitor
27 Aug 2020 07:13 #179666
by BeagleBrainz
Replied by BeagleBrainz on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
You can always keep the installation and build your own packages from source.
There is a package available in my repo called linuxcnc-build-deps that installs the stuff to build linuxcnc from git sources.
- seuchato
- Thank you received: 126
27 Aug 2020 11:46 #179680
by seuchato
According to the results, your machine seems to work on swap: "Swap useage: prerun: 16732, running: 27432" Add ram! Add 2 ram bars of same size. I would not go under 4GiB.
Greez chris
Replied by seuchato on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
I just posted the test results of the script on the specific topic of the script ...
Greez chris
The following user(s) said Thank You: aparecido
- aparecido
- Thank you received: 6
27 Aug 2020 12:08 #179682
by aparecido
I didn't quite understand, my motherboard accepts a maximum of 4gb, I could put two memories of 2gb giving 4gb or I can put two memories of 1gb giving 2gb, which would be the best option?
Replied by aparecido on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Greez chris
- aparecido
27 Aug 2020 16:56 - 27 Aug 2020 17:35 #179705
by aparecido
I'm not able to find Kingston or Markvision memories, I just found Digitron, Smart and Microware, but I don't know if they are good ... I don't know these brands.
Last edit: 27 Aug 2020 17:35 by aparecido.
- Thank you received: 7394
27 Aug 2020 20:59 #179740
Replied by tommylight on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
I was about to say that Clive uses it ....... to late !
- aparecido
27 Aug 2020 21:14 #179742
by aparecido
Sorry Tommy, I don't understand ...I was about to say that Clive uses it ....... to late !
27 Aug 2020 21:34 #179745
Oh sorry, that was meant for Beagle.
- aparecido
27 Aug 2020 21:41 #179746
by aparecido
Ok, no problem
- seuchato
28 Aug 2020 10:02 #179799
by seuchato
In the case of RAM: more helps more!
Taken from your test results here :[Obs: need to work on my script again, seems confusing]
If your MoBo has two slots, you can go up to 8GiB. With 4GiB, there should not be any change in swap usage, while running the script.
greez
chris
RAM related data:
Maximum Memory Module Size: 4096 MB
Maximum Total Memory Size: 8192 MB
Maximum Capacity: 16 GB
Maximum Total Memory Size: 8192 MBIf your MoBo has two slots, you can go up to 8GiB. With 4GiB, there should not be any change in swap usage, while running the script.
greez
chris
Time to create page: 0.285 seconds
