Raspberry Pi 4 Tutorial - fatal error
- Hakan
- Thank you received: 253
- Hakan
forum.linuxcnc.org/18-computer/36879-ras...pi-4?start=50#140800
I assume that other old packages can be found at the same place.
- JohnnyCNC
- Thank you received: 106
sudo apt install openbox
sudo apt install lxterminal
sudo apt install lightdm
I also lost my network connection (my fault) while debuild -uc -us was running and had to start it again.
Now, how do I start Linuxcnc from the command line? It is not on the Caja menus and I tried "linuxcnc" and I get "command not found". At this point I was just going to check latency as I don't have 7i76E yet.
- Thank you received: 4966
I should have entered:
This works too:
sudo apt install openbox lxterminal lightdm
If it is a built-from-source run-in-place version then before you can enter any linuxcnc commands you need
. ./linuxcnc-dev/scripts/rip-environment
- BigJohnT
- Thank you received: 1175
linuxcnc
I add them to the right click menu by opening a terminal and running the menu config tool
obmenu
I'll work on the tutorial some more when I return from vacation.
Thanks for the feedback.
JT
- JohnnyCNC
I'm going to try what Andy said and see what happens. I'm going to get a couple more SD cards so I can run through it again without wiping out this one.
- BigJohnT
gnipsel.com/linuxcnc/uspace/rpi4-emc.html
The next step after installing OpenBox is to install LinuxCNC...
JT
- JohnnyCNC
page again and it is now working. I must admit that every time I read about someone wanting to use a RPi my thoughts when to "Do you want to build a CNC machine or play with a Pi?" I must say that so far I am impressed with how snappy LinuxCNC feels and how bright the display looks. I have a Pi 4 with 4mb. Now to run the latency test and see how that goes.
- JohnnyCNC
Servo thread (1ms): 73079
Base thread (25us): 93953
If I run just the servo thread the number goes up over 100,000.
Anything I should try to lower the latency on the Pi4?
I may get a 7i76E and give this a try. Right now I'm using a 6i25+7i76+7i83
- Thank you received: 5187
